Clutch bearing rattle
saint
After switching from a 350 to a 370 I was hoping the horrible rattling clutch would be in the past, but the 370 I got does the same. Definitely sounds like the same thrust bearing issue that dogged the 350z.
Will upgrading to an aftermarket clutch solve it long term? Excedy are doing the 18MY clutches, I guess that'd fix it as the kit would have a new bearing included, and presumably a better design?
  • 1 month later...
  On 27/01/2018 at 22:43, ZMANALEX said:
The clutch release bearing is not turning when the clutch pedal is up.
It only starts to spin when you press the clutch pedal and the release bearing comes into contact with the clutch cover diaphragm.
Expand
thank you for the reply. so is that normal? or is it suppose to turn when the pedal is up?
