350Z Lambda sensor diagram help
Dannyg
Hi All
ive got multiple O2 sensor error codes coming up, but its not the sensors at fault
my garage reckons it could be something to do with the wiring and suggested they carry out a pin-out test, i have found info on what each pin does, and a diagram but my garage have said there is no Bank 1 sensor output pin
would something like this be on the main ECU wiring diagram?
has anybody had this before? and can any body point me in the right direction
thanks
Dan
On 12/12/2017 at 16:25, ZMANALEX said:
What codes are you getting?
Also what year and model is your car?
What adverse running issues are you having?
Just been going through original build on this car and read that it has berks hfcs on it, so its actually a common fault, will a remap get rid of the eml light for these codes?
