MOT advisory
heyho
I had a couple of advisories on my recent MOT. One was to do with brake/clutch pipe corrosion but the other was that the front drivers side tyre was close to the legal limit around the inside edge. Pity really as there must be 6mm of thread on the majority of the tyre.
I'm assuming that it needs some form of re-alignment. Anyone recommend somewhere around West Yorkshire area and what should I be asking for and how much should it cost?
Cheers
Click on Tyres in Shipley have a £70k laser alignment machine. They charge £40 for a full 4 wheel alignment. They will check it free when you have tyres fitted but the £40 is charged if you want it adjusted. You’ll get a full printout of all the measurements at the end. Tyres are as cheap as anywhere as well.
  • 4 weeks later...
