Spark plugs
Personally I'd recommend either NGK or Denso seeing as they're probably the 2 biggest names when it comes to plugs.
As for type I'd go for iridium every time, they're a little more expensive but offer the best spark and life span.
I didn't realise but apparently the DE and HR use different size plugs so just make sure you get the right ones, if you're not sure then there's plenty of traders on here that'll be able to help you out.
