plebpl Posted November 23, 2017 Share Posted November 23, 2017 Hi guys, im half way through changing my clutch, all the bolts etc are out from the bell housing. But the gearbox wont come away from the engine. I can get a few mil all the way around so I know its not a bolt, but it just wont come off. Is there some trick to this that im missing? or is it just a case of keep wiggling it until it comes free? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 23, 2017 Share Posted November 23, 2017 Providing there is not a bolt left in half screwed out then the box will probably just be sticking on the dowels. Rest the box on a tranny hydraulic jack and get a pry bar between the engine and the gearbox bell housing. Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 23, 2017 Share Posted November 23, 2017 53 minutes ago, ZMANALEX said: MTFU But yeah, just give it a bit more oomph and it'll come apart. Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 24, 2017 Share Posted November 24, 2017 Bottom of the gear box small dust cover held in with a 10mm bolt IIRC removed from engine side and its above the cross bar - did you get that? If so then as Alex said pry bar is the way ahead - even better 2 - one on each side so it come off square Quote Link to comment Share on other sites More sharing options...
plebpl Posted November 24, 2017 Author Share Posted November 24, 2017 Hi guys, thanks for the comments, I tried prying it apart for hours before I made the post, it was well and truly seized on there. In the end, I got a ratchet strap around the rear sub frame, and ratcheted the hell out of it. It eventual released with an almighty bang lol. Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted November 25, 2017 Share Posted November 25, 2017 (edited) Ah the almighty bang, the sound of broken things.... Edited November 25, 2017 by Willsy1980 Quote Link to comment Share on other sites More sharing options...
