Loggy747 Posted November 13, 2017 Share Posted November 13, 2017 Flew back home to Ireland after 10 weeks away to put the zed through the MOT. For those who aren't aware, the MOT is much more stringent in northern Ireland compared with England. Anyway, I got into the car and the airbag light was flashing again. This happened a few times before so I had already researched and found a video which suggested turning the ignition 4 times. This got the light off until I was at the MOT centre and was asked to turn the car off, at which point the airbag light decided it would be a nice time to come back on. And the poor zeds' fate was sealed. The problem is I can't get this light off now, it only stays off until I turn the car on again and then it comes back on. Is there a more permanent fix? Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted November 13, 2017 Share Posted November 13, 2017 Mine turned out to be a a failed "clock spring" thingymajig near the steering wheel. Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted November 14, 2017 Author Share Posted November 14, 2017 How did you get to that conclusion? I don't even know where to start looking? Quote Link to comment Share on other sites More sharing options...
Gudzy Posted November 14, 2017 Share Posted November 14, 2017 Its often that the connections under the seats are very sensitive and have lost connection. I'd recommend to unplug and then plug them back in again and then do the reset after that. Quote Link to comment Share on other sites More sharing options...
mr v6 Posted November 14, 2017 Share Posted November 14, 2017 Common on my old 406 Coupes, it was the connector under the seat in them, we cut the connector out & solder the wires together. Assuming yours is the same issue? Might be worth having the codes read to narrow it down. Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted November 14, 2017 Author Share Posted November 14, 2017 Ok thanks I'll have a look. Hopefully that's all it is. Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 15, 2017 Share Posted November 15, 2017 It's nearly always the yellow connector under the passenger seat, the reset works fine unless the fault is still there then the light will come back on every time. Try the connector under the passenger seat then do the reset hopefully you will be good to go after that, The clock spring failure cause the light to come on as it detects a fault in the steering wheel air bay I have only seen that on one Zed so far, it's not a common problem from what I know. Quote Link to comment Share on other sites More sharing options...
karlh Posted November 15, 2017 Share Posted November 15, 2017 Simply going through the ignition key cycle to extinguish the light doesn't solve the underlying problem. I recommend downloading the US service manual for your model year and going through the diagnostic steps in the srs.pdf section. This will tell you what part of the system is at fault. While US spec cars are not identical to yours, I believe the airbag system is. Quote Link to comment Share on other sites More sharing options...
colesl4w Posted November 15, 2017 Share Posted November 15, 2017 I feel your pain. Mine has been intermittent. Mine was also the clockspring in the steering wheel. Really the best bet without messing about is to take it to someone with the correct diagnostics machine and get the error read. It'll tell you whether it's the seat or the clockspring, or something else. Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted November 16, 2017 Author Share Posted November 16, 2017 Thanks for the advice lads. Currently back in London so trying to get it sorted from over the water is proving a painful process! Quote Link to comment Share on other sites More sharing options...
