Stutopia Posted November 12, 2017 Share Posted November 12, 2017 First off, this is for my BRZ not a Z. Sorry Zedders. I’ve picked up some unequal length headers to give me a bit more noise and a bit more of a Subaru burble - they’re not the massive job on the BRZ that they are on the Z. They are wrapped for now, but I’m not that keen on keeping them that way as I don’t want moisture, particularly salty winter and coastal moisture, sitting in the wrap. As an alternative I was thinking of getting them ceramic coated but I don’t know much about it. Anyone got things ceramic coated? Was it worth it? Can you recommend somewhere (ideally NW, but anywhere will do)? Are there any drawbacks to ceramic coatings? Thanks gang. Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 12, 2017 Share Posted November 12, 2017 I've had ceramic coatings done on exhaust parts before, but that was on turbo applications where you're dealing with much higher temps. Was it worth it? No idea, never took pre/post temps to find out, but it looked pretty No real drawbacks that I'm aware of, but obviously you need a total coating to prevent anything getting underneath it and also reasonably thick so it does the job, On relatively low power NA (i.e. anything short of pure race engines) I wouldn't bother if I'm honest, unless it's for the looks. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted November 13, 2017 Author Share Posted November 13, 2017 5 hours ago, Ekona said: I've had ceramic coatings done on exhaust parts before, but that was on turbo applications where you're dealing with much higher temps. Was it worth it? No idea, never took pre/post temps to find out, but it looked pretty No real drawbacks that I'm aware of, but obviously you need a total coating to prevent anything getting underneath it and also reasonably thick so it does the job, On relatively low power NA (i.e. anything short of pure race engines) I wouldn't bother if I'm honest, unless it's for the looks. That’s interesting, I’d not considered just leaving them bare As you’ve also got a scoobie, I’m guessing it’s a PITA to do the plugs on that, just like the BRZ? If so, you reckon they’re any easier to do with the headers off, so worth doing at the same time? Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 13, 2017 Share Posted November 13, 2017 I don't think the plugs are too hard to do on an Impreza as there's a fair bit of room to manouevre, but I've not actually tried it myself yet. The ones on the 911 were a piece of cake though. Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted November 13, 2017 Share Posted November 13, 2017 As Ekona says, i personally wouldnt bother unless you are suffering with high under bonnet temps, or running fi where its also a benefit to get exhaust gases out quickly by keeping them hotter in the pipework. 1 Quote Link to comment Share on other sites More sharing options...
