Beefy Posted November 2, 2017 Share Posted November 2, 2017 Hey all, I know a lot of people are interested in the Zakustech rear window louvers, Turns out, G.R.A.M.S styling has started manufacturing their own for £200 + (Depending on Carbon Fibre, spoiler, etc.) I bought them straight away as I have the G.R.A.M.S Skirts already and their quality is pretty good.http://www.gramsstyling.co.uk/shop-2/nissan-350z-rear-window-louvers-2/ Will report on fitting (Probably do a quick guide or something) and finish. They look like they're connected with tape. I would suggest 3M VHB tape for fixings personally. Looks like it will need a rear wiper delete as well. Will report as soon as they arrive. - Beefy 1 Quote Link to comment Share on other sites More sharing options...
PPod Posted November 2, 2017 Share Posted November 2, 2017 This looks promising. What option did you go for black,white or carbon fibre ? Quote Link to comment Share on other sites More sharing options...
valy Posted November 2, 2017 Share Posted November 2, 2017 interesting but by the looks of it only has a gel coat on top so will need spraying for a gloss finish keep us updated anyway Quote Link to comment Share on other sites More sharing options...
Beefy Posted November 3, 2017 Author Share Posted November 3, 2017 6 hours ago, PPod said: This looks promising. What option did you go for black,white or carbon fibre ? Went for the black, Will let you know how the finish is. If it's the same finish as the skirts, they'll be no need to repaint them. Quote Link to comment Share on other sites More sharing options...
mr v6 Posted November 3, 2017 Share Posted November 3, 2017 Like the look of louvers but the fact they can only be fitted one way using adhesive, it coming off at motorway speeds worries me. Quote Link to comment Share on other sites More sharing options...
Beefy Posted November 3, 2017 Author Share Posted November 3, 2017 7 hours ago, mr v6 said: Like the look of louvers but the fact they can only be fitted one way using adhesive, it coming off at motorway speeds worries me. I did R&D for Nissan Europe for a while in their aftersales and accessories department. Pretty much all of the exterior trim pieces is held on with tape. In all the tests I've never know one to fail during testing, and we've had vehicles up to 120mph+ without full adhesion. As long as you prep the area correctly, so their is no dirt, decent contact patch, it'll be fine. If you're mega worried, use 3M VHB tape, the stuff is genuinely more robust than most mechanical fixings. Quote Link to comment Share on other sites More sharing options...
MDMetal Posted November 9, 2017 Share Posted November 9, 2017 While I still go for bolts as well with larger pieces if your using adhesive that has maximum contact with the two pieces your effectively spreading any load across a much wider surface. Imagine a spoiler, 6 bolts, so the load on the spoiler is being spread over 6 points, if your exerting 6kg of force then each bolt is supporting 1 kg (assuming an even load which obviously never happens) that's 1kg on the mount points, (maybe 2cm square) with adhesive your looking to spread that 6kg over say 1 square meter, your exerting much less force on a single point. Most adhesive works from suction as well, once gripped and solid it's very hard to remove! It's perhaps not obvious when thinking about because you think the bolts are stronger, that's true but it's not the bolts that are the weak point it's your mounting points! Quote Link to comment Share on other sites More sharing options...
Beefy Posted November 23, 2017 Author Share Posted November 23, 2017 Okay, so I've finally been able to get back for some modding goodness. Car is currently away having the PU Nismo V2 bumer painted. Anyway, finally the louvers have arrived: I must admit, they're not up to the same standards as the other G.R.A.M.S Items I've recieved. and required a bit of sanding. The paintwork and cutting from the mould aren't amazing. Although from a distance, you wont notice. I'm a bit of a stickler for the details, so I've spent some time sanding bits down where the paint has been peeling, and where the molding was a bit @*!#. They're surprisingly thin for fibreglass parts, but do have some ribs built in, I assume as this part does have to bend, it supports the structure a bit more... The underside did need sanding ithout a doubt. the quality control at G.R.A.M.S this time hasn't been great. Unlke the skirts I got from them which were fantastic... Going to do some painting tomorrow, a few times with primer, then a clear coat. Will try to fit them in the evening if I feel they're okay. I'm more interested in the fitment of these parts than the finish, as all fibreglass parts are a bit naff IMHO. I did expect better quality however. Quote Link to comment Share on other sites More sharing options...
Beefy Posted November 23, 2017 Author Share Posted November 23, 2017 I've also spent some time cutting excess from these with a dremel. Remember if you're cutting with fibreglass to always be in a well ventalated area and wear a mask. Quote Link to comment Share on other sites More sharing options...
valy Posted November 24, 2017 Share Posted November 24, 2017 I got to say that actually looks terrible .....it is very disappointing paying money for a crap product...that is why I had my doubts about them.... If I were you I will send it back ,ask for the refund and get a Zakustech one Quote Link to comment Share on other sites More sharing options...
Apoc124 Posted November 24, 2017 Share Posted November 24, 2017 Thats a shame, i have the GRAMS sideskirts aswell and as you say they're really good quality. maybe this was just a bad mould seeming its a new item, still tempted by these myself so will be interesting to see what the fitment is like aswell if they are as good as the skirts. Quote Link to comment Share on other sites More sharing options...
Beefy Posted November 25, 2017 Author Share Posted November 25, 2017 I'm going to fit them anyway, will see what i think when they're all on. If they look alright for a distance, I will keep them and probably use filler and paint them again in the summer. I'm tempted to say they might break when fitted as it's colder than normal at the moment, but we'll see. Painting has commenced today. 3 coats of primer, 2 coats of colour (Black) and will proceed with 2 clear coats for good measure. Looking for Satin/Matt black ideally. The paint has split in a few places and looks patchy already. It seems that it's just a really bad mold that they're using, They need to refine the process. Will update with more pic as and when they're fitted. Overall at the moment 4/10. Quote Link to comment Share on other sites More sharing options...
milseyman Posted January 27, 2018 Share Posted January 27, 2018 i got the carbon one the quality is crap aswell am waiting on them getting back to me before a start shouting at thum Quote Link to comment Share on other sites More sharing options...
PPod Posted January 27, 2018 Share Posted January 27, 2018 Got this email today So can now directly order from UK. Works out £650 but no idea on import charges Quote Link to comment Share on other sites More sharing options...
Jay84 Posted January 27, 2018 Share Posted January 27, 2018 Maybe I'm just old, but I'd not buy from someone who calls me Fam on an email 3 2 Quote Link to comment Share on other sites More sharing options...
parello9 Posted January 27, 2018 Share Posted January 27, 2018 1 minute ago, Jay84 said: Maybe I'm just old, but I'd not buy from someone who calls me Fam on an email They are a family from zoicety so treat anyone like that with a Z 1 Quote Link to comment Share on other sites More sharing options...
Jay84 Posted January 27, 2018 Share Posted January 27, 2018 In that case its perfectly acceptable. 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted January 27, 2018 Share Posted January 27, 2018 Actually I think you were right the first time...! 1 Quote Link to comment Share on other sites More sharing options...
PPod Posted January 27, 2018 Share Posted January 27, 2018 Big cartel Quote Link to comment Share on other sites More sharing options...
veilside z Posted January 27, 2018 Share Posted January 27, 2018 On 23/11/2017 at 22:21, Beefy said: Okay, so I've finally been able to get back for some modding goodness. Car is currently away having the PU Nismo V2 bumer painted. Anyway, finally the louvers have arrived: I must admit, they're not up to the same standards as the other G.R.A.M.S Items I've recieved. and required a bit of sanding. The paintwork and cutting from the mould aren't amazing. Although from a distance, you wont notice. I'm a bit of a stickler for the details, so I've spent some time sanding bits down where the paint has been peeling, and where the molding was a bit @*!#. They're surprisingly thin for fibreglass parts, but do have some ribs built in, I assume as this part does have to bend, it supports the structure a bit more... The underside did need sanding ithout a doubt. the quality control at G.R.A.M.S this time hasn't been great. Unlke the skirts I got from them which were fantastic... Going to do some painting tomorrow, a few times with primer, then a clear coat. Will try to fit them in the evening if I feel they're okay. I'm more interested in the fitment of these parts than the finish, as all fibreglass parts are a bit naff IMHO. I did expect better quality however. OMG what a finish to send out. Hope you can get it to your satisfaction Quote Link to comment Share on other sites More sharing options...
Beefy Posted January 30, 2018 Author Share Posted January 30, 2018 On 27/01/2018 at 22:24, veilside z said: OMG what a finish to send out. Hope you can get it to your satisfaction Yeah, pretty shocking. They're sending another set out soon however. If these ones are also poor quality, I'll send them back and get a full refund. On another note, rumours that Tarmac Sports will be doing rear louvers soon, as well as the fact you can now buy them from Zakustech as well should mean there is a nice selection to choose from soon. Quote Link to comment Share on other sites More sharing options...
Jake.Lowther Posted March 12, 2018 Share Posted March 12, 2018 Any news on this interested in buying them, might risk it for a chocolate biscuit Quote Link to comment Share on other sites More sharing options...
Apoc124 Posted March 13, 2018 Share Posted March 13, 2018 On 3/12/2018 at 08:18, Jake.Lowther said: Any news on this interested in buying them, might risk it for a chocolate biscuit steer clear of them there is alot of people sending them back after they bought the grams ones for **** poor quality, either wait until someone here in the UK can make a decent metal set or buy from the US Quote Link to comment Share on other sites More sharing options...
Jake.Lowther Posted March 14, 2018 Share Posted March 14, 2018 22 hours ago, Apoc124 said: steer clear of them there is alot of people sending them back after they bought the grams ones for **** poor quality, either wait until someone here in the UK can make a decent metal set or buy from the US How bad is bad, i know a lot of FRP parts need work doing to them your crushing my dreams Zacks waiting list takes ages Quote Link to comment Share on other sites More sharing options...
Darkside Posted March 14, 2018 Share Posted March 14, 2018 G.R.A.M.S. are getting worse as time goes on. When they started out, the general work was quite good (just needing finishing off as a general rule) but now I find that they are just getting stuff out so fast that they don't seem to be bothered. The quality of this louvre, in my opinion is disgraceful and at best should only have sold as a 'second'. Sadly, the more we accept this quality from companies, the more they are happy to produce it. Well done for demanding a new one and you're absolutely spot on with not accepting anything like this. Quote Link to comment Share on other sites More sharing options...
