350z clutch problem... help!
reeceybeaney
First real mechanical/technical issue today with the 350z.
Clutch goes to the floor and doesn't return for a good 5 seconds. So I carry on driving as normal thinking "it's going to do it again":headhurt:.
Clutch goes to the floor and doesn't return at all.
There's a leak of clutch/brake fluid under the car towards the passenger front side, guessing it's a broken clutch line hence why the clutch doesn't work?
Fluid was dripping from the black hose/line in the photo, might be hard to see sorry!
Can anyone shed any light or anyone experienced this previously?
Thanks!
Reece
Edited by reeceybeaney
8 minutes ago, ZMANALEX said:
If it is a DE then it will probably be just the external slave cyl.
Replace the slave and the hose and bleed with fresh fluid and all should be good. :thumbs:
It is a DE, always forget to say aha.
Is the slave cylinder causing the leak or is it possible the line is broken? Once I get it home tomorrow I will have a proper look and no doubt be in touch!
