Battery disconnect reconnect problem
Jack Carter
Hi all,
Regards my roadster.
Had to disconnect the negative terminal from the battery earlier today. Followed the procedure in the manual to the letter. Then followed the instructions to reconnect the battery. All went well except now, when I open the driver door, the window drops a fraction as it should, but when I close the door, it does not go back up that little bit.
Any ideas?
Many thanks in advance.
