Guest Posted October 14, 2017 Share Posted October 14, 2017 Hey everybody =) I was intending to flush and replace my coolant before it starts to get cold. I have the necessary de-ionised water for the flush and some Fuchs Fricofin LL as replacement coolant which I intend to use at a 1:1 ratio with the water. As always my preparation has been left to the last minute and as a noob I am finding that the guides I am able to find locate aren't super comprehensive, and I don't want to bugger anything up. I've had a search of the forums but can't really find a lot of detail, and there aren't any decent youtube videos for the 350z. Is anybody aware of a link to a suitably basic source such that even an idiot couldn't get it wrong? Luke Quote Link to comment Share on other sites More sharing options...
mr v6 Posted October 14, 2017 Share Posted October 14, 2017 Is the Z specific to Nissans green coolant, or could it be substituted for an alternative like red Dexcool or similar? I would replace with the genuine stuff personally. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 14, 2017 Share Posted October 14, 2017 If you follow your plan, then you are going to get yourself into all sorts of bother with airlocks. If I was you I would just drain the radiator and refill with L248 which comes as a premix and is not expensive. I would not drain or flush out the block. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 14, 2017 Share Posted October 14, 2017 Ah ok. I thought the airlocks were easyish to remove with the bleeder screw. Does stuff not build up that needs flushing out then? I thought it did, but if not then I'll get the different coolant as advised and just do the radiator. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 14, 2017 Share Posted October 14, 2017 If you are confident on bleeding the system and have hours to spare then crack on mate. Of course, it is always best to flush out and replenish with new coolant, however, most members have run into issues with your proposed plan. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 14, 2017 Share Posted October 14, 2017 Well as most members are significantly more experienced than I, I'll probably go with your suggestion instead =) Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 14, 2017 Share Posted October 14, 2017 Wise decision, drain rad, refill slowly with L248, perhaps a quick bleed through the bleed screw if required, job done. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted October 15, 2017 Share Posted October 15, 2017 13 hours ago, ZMANALEX said: If you follow your plan, then you are going to get yourself into all sorts of bother with airlocks. If I was you I would just drain the radiator and refill with L248 which comes as a premix and is not expensive. I would not drain or flush out the block. Alex how would airlocks present them selves? In the form of overheating? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 15, 2017 Share Posted October 15, 2017 If you overheat and lose or do not lose fluid then air will accumulate in the system. Your heater may start to blow cold on low rpm. Fix the overtemperature issue and bleed the system. Fitting a coolant header makes kids play of the air lock issue. Quote Link to comment Share on other sites More sharing options...
Jay84 Posted October 15, 2017 Share Posted October 15, 2017 My celica was a pig to bleed, mainly because the expansion tank was lower than the higher coolant channels in the engine. Quote Link to comment Share on other sites More sharing options...
