Koukicuda S14A, 350z handmedowns.
evilscorp
So this 41761501_10160916556390441_2705860388964
is going in this
41752327_10160916556495441_1709600036976
Well the important bits are.
Diff,driveshafts,wheel bearings and maybe the handbrake setup as the 200sx uses a cable on caliper design. (no internal drums)
Fortunately the 350z subframe looks like its from a newer car or hasn't seen much salt as all the bolts are good and should save me a bit of cash if I can use them on the 200sx subframe.
The shocks look in half decent nick if anyone wants them? (one is minus the welded nut, but you can just fit a nut to the normal bolt anyway like most aftermarket shocks.)
I may keep some of the arms as spares but if anyone needs them let me know.
So 350z wheel bearing bolts are 5mm wider spaced apart that s14 items so they won't be getting used =( guess they are now spare for the Z. But new s14 items aren't expensive so I will just have to order some and push out the 5 lug wheel axle from the old ones.
This makes the 350z rear handbrake conversion more difficult as the plate holes wont line up..... Think I will leave this for a very distant future project and stick the old system back on for now.
Now that Ive finished messing about with dismantling things I don't need I will hopefully drop the fuel tank tomorrow when I get up and set about ordering new braided fuel lines.
Kinda became sidetracked today as I was fed up struggling to find the correct heater controls in the chrysler 300c daily so ended up soldering in some new LED's and ate up most of my morning and I have work this afternoon =(
42472056_10160957165640441_9060922896112
So back to the koukicuda,
Took the heat shield off the tank. . . . ok the first clip disintegrated and I ended up just pulling the rest off violently.
42491590_10160957165645441_2636486290492
The plastic fuel filler neck guard didn't help the corrosion resistance much.
42506573_10160957165635441_3747828998390
The moment I touched it the thing started to fall apart and would have been leaking fuel soon I imagine.
42617411_10160957165405441_7127756995196
Also found more rust so poked a hole.
New filler neck needed as the bracket on the chassis is dead and so is the metal neck, the plastic part looks ok but these tanks are known to leak so I may have to coat it in something (some people use truck bed liner?)
These fuel lines have been disconnected but I reconnected them as there is still a bit of fuel in the tank and I don't want to leave the garage with an open source of fuel, hopefully tomorrow for dropping..... removing the old tank.
42461361_10160957165625441_3771006127978
So the fuel tank in these is kinda big, just a couple more things to check then the engine and trans is coming out.42683081_10160964141640441_8257515977399
Straps are dead.
42578499_10160964141545441_8014820342008
42600333_10160964141470441_8630491057643
Need to wire wheel this all to see if its going to need patches welded here also.
42607429_10160964141285441_2092312997786
old brake and fuel lines are going to be replaced with braided and -6AN hose.
42672677_10160964141180441_6103663537144
42664060_10160964140800441_3426335779863
42649478_10160964140680441_1571140573505
Hopefully I can weld a new bracket to this filler neck.
42659937_10160964141020441_6741667490012
42658396_10160964140960441_5270717199168
last time anything auto will be near the car.
42586425_10160964140865441_5990710591658
42591569_10160964140530441_7055502537037
Two 14mm nuts are all that seem to hold the engine to the mounts so they are off, now I just need to find a good place to bolt my engine leveler... nothing on the front looks good, only stuff on the side :thumbdown:
42654651_10160968550045441_3567247901589
42663244_10160968550155441_7217280906967
Still need to undo the gearbox mount but waiting until I know where to lift from/ slings arrive.
Engine out.
43498457_10161009499835441_6677016816184
Ended up using a mix of sling and chains on bolts.
43565409_10161009499930441_8678963684883
43518825_10161009499970441_7229184559152
Plan to tidy this up and remove some unused pipes and weld some holes shut in the firewall.
43528137_10161009500025441_5166709575344
So my first mistake of quite an easy job (surprisingly) was not to undo the bottom two gearbox bolts.
43471275_10161009500060441_5028643517992
Back up again and jack under the box as doing this myself was a bit scary as this sh#' is heavy.
43624171_10161009500145441_7000819949727
Then I realized its not like roadkill american V8's the dam torque converter still has lots of oil in it and is bolted to the flywheel, which need to be accessed through an inspection hatch on the bottom of the block (hopefully).
43473516_10161009500205441_5722456984574
Getting the box off took a lot of wriggling. But now I can swap to the Apex exhaust 3" elbow easier and a few other bits and bobs (remove AC pump,)
Glad I have the hoist as it was a pain to drain the fuel tank but used a sling to tilt it and drain from the filler pipe. (nearly empty so the fuel pump will be swapped soon.)
Turbo shaft has 1-2mm of play so should be fine for a few more miles,
 44171303_10161042481680441_2891156496568
Oil return line will need changed, if I cant clean the pipe up it will be swapped for some braided hose.
44208387_10161042481935441_7208262837150
Sadly the original exhaust stud is too long to fit the 3" apex turbo elbow so it will need shortened and then the elbow might need some bashing or grinding to fit the 350z gearbox, since its a lot larger.
Removed the last few items from the wheel wells before the cutting and welding work begins.
44261250_10161042481490441_2486464659096
44324901_10161042481395441_2127604499244
To remove the steering and front subframe I think I just have to undo a clamp beside the red paint pen mark (not sure), then four big bolts under the subframe. Then I should be able to remove the lot for a clean and new steering rack bushes and maybe some offset spacers and other bits =)
44342353_10161042481590441_8981987891202
steering rack and subframe removed along with some radiator brackets and other stuff.
44327452_10161045635770441_5832158682766
44478131_10161045635780441_8543779812580
44460841_10161045635865441_7498402064272
44318040_10161045635550441_4067118520737
44327503_10161045635665441_4514597453772
main  chassis rails are in good condition on the inside, not so good on the outside, have yet to look underneath =/
Cleaned them up and some of the suspension turrets then coated with zinc primer to stop them rusting while I cut out the death and weld in fresh metal.
44298375_10161045635535441_3693818886995
Quite boring but these pictures help understand where stuff goes so bare with me.
  • 3 weeks later...
Some upside down welding... still needing more practice but I have plenty to learn  on :lol:
45579909_10161117012270441_8959359409327
45710546_10161117012315441_5615693001062
Sadly my daily driver 300C decided to seize both front brakes on a trip to Manchester so having to try rebuilding the calipers.
45541212_10161116963020441_9071779186162
45739849_10161116962820441_1823297476388
Think my iphone camera is on the way out =(
45665189_10161116962825441_1415694604572
None of the videos I seen online had this problem. Both pistons came out fine with the compressed air but neither boot wanted to simply be pulled out!
I think they must have melted onto the caliper as nothing could get them off and they just ripped with pliers. Ended up having to scrape and burn them out, hopefully they work as new calipers are nearly £300 for a car I don't love and want rid of (once the koukicuda is ready).
45642432_10161116962830441_5573235131923
45630286_10161116962815441_8416926476024
As clean as I could get, the inner seal crevice is rubber free and they fortunately came out fine.
45611442_10161116962865441_3759432629930
having to waste more time on the chrysler as I realized the dust boots need to be pressed into the brake caliper so now I need to make a tool to do this (one less cheap hole saw no doubt.)
meanwhile I got some parts back from the powder coaters... someones favourite colour on the forum:lol:, probably end up covering them in waxoil as well for extra protection.but they seem hole free, hopefully the rust should remain dormant under it.
46208165_10161139880360441_6269228925767
Started making replacement panel for my tubs to begin then....
46463324_10161161431800441_1188337796339
46482450_10161161431670441_5719533499120
I didn't want to do a half ass job so thought I better see whats inside the frame rail.
46480454_10161161431525441_1859973104072
46472484_10161161431425441_6660295640917
Lots of spot welds hold this bit in place.
46499018_10161161431305441_1368869874679
Huuummmm...
Need to treat this stuff and hopefully I can save the U section with just grinding, the brackets inside look ok.
46482502_10161161431155441_1874206239144
Need to remove the rest tomorrow and start grinding and copying where to put the spot welds.
  • 3 weeks later...
Bought some parts and did a tiny bit of work.
47578062_10161224981275441_5181111725969
removed the torque converter then got stuck with the flywheel bolts as I need to make a flywheel stopper.
47687045_10161224981925441_653520645788347450886_10161224981835441_3940492486736
Its far away so you can't see my poor welds.
47396718_10161224981770441_1641583380099
I don't have a fancy metal bender and my metal work skill's are lacking, but I get there.
47680422_10161224981710441_9170192400335
I know it doesn't line up but its getting tubed so F@* it.
47572433_10161224981615441_8467389640217
47574431_10161224981530441_5768638358431
Needed the template to line the spot welds up with the brackets.
47448873_10161224981490441_1733513783520
47398293_10161224981410441_4801567579145
And right at this point I ran out of zinc weld through primer and the missus was on her way home so play ended until tomorrow.
47571961_10161226136075441_2838529974527
Can't afford watanabe's and there were only 3 rota rkr's left anywhere in the size I wanted go I bought these... could have bought these many many times over compared with the vossen works on the Z :lol:
47576831_10161226136115441_9491723792532
All new hubs, been waiting for the driftworks black friday sale for a long time ;)
Flywheel lock turned up, but it's not quite right for this engine but mehhh, done the job:lol:
48364748_10161252400725441_1857838088714
I was going to fit the orc carbon clutch and flywheel but I figured I better wait for some new bolts?
48364782_10161252400700441_6179939553571
Got back to the wheel tub... takes ages to do one panel =(.
48371215_10161252959980441_8687657188316
48098271_10161252400660441_3679290842289
48379252_10161252400580441_6417339472811
48368568_10161252400545441_8040365660728
48365967_10161252400495441_7012782039237
Got as far as cutting the curve to a rough shape, still needs some fine tuning before I tack it up, Probably going to stitch weld the inner and outer plate above then seam sealer to stop any crap getting in between the two panels.
48270361_10161252947095441_1098253743524
It takes lots of hours to have nothing much to show.:sleep:
But only seconds to buy sh#t, I don't need right now....
48388882_10161281382300441_6607811136265
48377347_10161281382305441_2410602557257
The seam sealer and gun I was using wasn't fun, took a lot of effort to squeeze the stuff out, not a neat job but it wont be seen and its not a show car. Once it dries overnight I will stick another layer of primer over it.
Busy time of year so only getting a half hour here and there to work on the car.
Subframe bushes.... trying a different method of attack than burning which sucked on the 350z. Fortunately rust doesn't hold rubber well and this is a lot older and the oem bushes aren't great.
48396940_10161288264955441_4335671950899
Hopefully the metal sleeve can be punched out with a chisel after some initial cuts are made.
49012458_10161288265050441_8078306534238
