KuroKiddo Posted September 4, 2017 Share Posted September 4, 2017 Hi just gathering the parts ready for installing coilovers and alignment, looking to lower the car -30mm using BC BR coilovers so not true coilovers at the back, already got driftworks camber arms for the rear, question is do I need to get adjustable rear toe bolts? Prefer to have everything I need for the setup on the day, thanks! Quote Link to comment Share on other sites More sharing options...
Olly350z Posted September 8, 2017 Share Posted September 8, 2017 You may get away with using the oem bolts, you may not. Ive gone pretty low and they managed to get my toe in spec on OEM bolts. Cambers out but Ill adress that in the future Saying that, it makes sense to get aftermarket toe bolts, stillen sold by @Tarmac@TarmacSportz are a good option. Provides you with spares in the event that you snap a bolt, which is likely. Get your alignment done ASAP once the coilovers have settled as it WILL be out Quote Link to comment Share on other sites More sharing options...
