PetrolheadNut Posted September 4, 2017 Share Posted September 4, 2017 Had a quick search, but can't seem to find what this connector is called? Or where to buy some? The plastic quick release parts that is, part of the washer bottle system. Found you can buy the pipework set, but I'm just after the connectors. Thanks! Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted September 4, 2017 Share Posted September 4, 2017 (edited) Are they check valves ? would seem weird to use a connector like that when the rest is just push fit stuff. Edit: Here are all the parts and item codes for the washer system https://parts.nissanusa.com/nissanparts/index.cfm?action=replacement&groupid=E§ionid=289&jointvehid=11067&siteid=14 Edited September 4, 2017 by Willsy1980 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 4, 2017 Share Posted September 4, 2017 Plenty connectors and pipework in stock, Just drop me a PM if I can help further. Alex. Quote Link to comment Share on other sites More sharing options...
PetrolheadNut Posted September 6, 2017 Author Share Posted September 6, 2017 On 04/09/2017 at 22:11, ZMANALEX said: Plenty connectors and pipework in stock, Just drop me a PM if I can help further. Alex. PM'd, thanks. Quote Link to comment Share on other sites More sharing options...
PetrolheadNut Posted September 6, 2017 Author Share Posted September 6, 2017 On 04/09/2017 at 18:07, Willsy1980 said: Are they check valves ? would seem weird to use a connector like that when the rest is just push fit stuff. Edit: Here are all the parts and item codes for the washer system https://parts.nissanusa.com/nissanparts/index.cfm?action=replacement&groupid=E§ionid=289&jointvehid=11067&siteid=14 Thanks for this. I found the pipes + connectors on a different diagram as part of the pipes which share the washer fluid between each side, as well as to the headlamp washers which is what's on mine. Just not the connectors on their own. Quick release for the bumper I'd assume, just that it empties itself at the same time. Quote Link to comment Share on other sites More sharing options...
