Guest Posted August 30, 2017 Share Posted August 30, 2017 Hi just changed my boot for another one but cannot close it with existing boot struts. are there 2 types available? it seems the ram body needs to be slightly shorter as all fine when struts are off thanks Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted August 31, 2017 Share Posted August 31, 2017 Have you fitted the bracket which bolts onto the car the right way around ? Should look like this. Quote Link to comment Share on other sites More sharing options...
Flashback Posted August 31, 2017 Share Posted August 31, 2017 2 hours ago, SHEZZA said: Have you fitted the bracket which bolts onto the car the right way around ? Should look like this. +1 for this being the most likely cause. Very easy to do by accident. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 1, 2017 Share Posted September 1, 2017 Will double check tomorrow , cheers Quote Link to comment Share on other sites More sharing options...
Guest Posted September 2, 2017 Share Posted September 2, 2017 Nope not that, plus my bracket that attaches to car has the ball joint in the middle where. I notice your is more towards the bottom? Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted September 3, 2017 Share Posted September 3, 2017 Not my car just a generic pic of a standard one. That's strange then have you got a pic of yours ? Maybe it's the wrong bracket/strut ? 12 hours ago, semmco said: Nope not that, plus my bracket that attaches to car has the ball joint in the middle where. I notice your is more towards the bottom? Quote Link to comment Share on other sites More sharing options...
