RobPhoboS Posted August 30, 2017 Share Posted August 30, 2017 I believe my front Brembo's need the seal kit, front right does creak a bit when applying the brakes at very low speeds. However, I just wondered what happens when the seals are old and perished, what actually happens ? Secondly what grease do you use for the seals ? The FSM says "Do not use Nissan rubber grease". 'Do not use Nissan Rubber Grease (KRE00 00010, KRE00 00010 01) when assembling' 'Apply polyglycol ether based lubricant to the piston seal' If you want the guide it's here (he uses brake fluid to lube the seals though):https://g35driver.com/forums/brakes-suspension-diy/402581-diy-brembo-rebuild-kit-seals-dust-boot.html 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted September 28, 2017 Author Share Posted September 28, 2017 Any takers on this, as I think I'll do this over winter anyway. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 28, 2017 Share Posted September 28, 2017 The seals very rarely perish, however, the piston dust covers do. And use Red Rubber grease for assembly: 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted September 29, 2017 Author Share Posted September 29, 2017 Cheers mate Quote Link to comment Share on other sites More sharing options...
