Bustalyric Posted August 14, 2017 Share Posted August 14, 2017 Hey guys So I finished my 12hour night shift and got back to my car only to find I couldn't put it in gear, when I had just switched the car on, even tried reverse and it was just making some loud grinding noise, literally had to force it in gear, when the car was off it was going in all gears fine. Eventually started driving and it was getting easier to put into gears, but then the peddle was only coming upto half way, after about 15mins it was driving perfectly fine. I just hopped in the car now to go for a drive and same issue had to force it into reverse, and 1st. The clutch was changed to a competition stage 2 clutch and also had the flywheel changed same time, at the time of installing the garage, had trouble with master and slave cylinder, so both were changed, I tried contacting the garage that did the work and they've closed down now. Any advice on what to do? Quote Link to comment Share on other sites More sharing options...
Redsky Posted August 14, 2017 Share Posted August 14, 2017 First thing to check would be your fluid level. If its low put some in pump the clutch and see if it comes back to normal then watch it over time and see if its leaking out. Thats my first idea anyway. Quote Link to comment Share on other sites More sharing options...
