Diff with fins cant be jacked off???
Rob350
My last diff before i had it replaced had a couple of the fins broke which may have been a result of someone doing this, im not sure, but the main diff housing behind is smooth so can you just reach the trolley a little further underneath?
From what i understand you jack from the diff at the back but not on the little metal fins as they bend and at the front you jack from the circular jacking point right in the center of the car almost in line with the front axle. I placed jack stands on the two lines of metal that run from front to back on the car and that seemed to hold up well. I havent tried to jack up the back of the car yet.
8 hours ago, Rob350 said:
Genuine question....
are you being serious?? Can you actually Jack off that??
Yep that's the official jacking point for the rear I think. Its the bit I've used every time I've had the back end off the ground over the years.
