Mark350Z Posted August 9, 2017 Posted August 9, 2017 (edited) Hi all, Hoping someone can provide some hope here as I'm struggling to find the source of a really irritating squeaking noise. Some context on when 'the squeak' happens: occasionally under load at slow speeds, i.e. hill start or rolling onto my ramps at home at idle at traffic lights etc. seems to be a constant sound, doesn't change with engine speed. Interestingly it does seem to go away if you give it a little throttle when sat still. general driving it doesn't make any sound but occasionally you might get it at lower revs in high gears, i.e motorway driving. most commonly it happens when I'm sat at a standstill which is infuriating as it's louder than the car! seems to be coming from in front of the driver, hence why I've got the wheel off to poke around in there in the video. I originally though it was something to do with the pulleys or belts but that went away when I found it makes a quick squeak if you slam the door for about 1/4 second. I think it's something that is loose and just rubbing against another part as it sound quite metallic. I've attached a link to a video which I hope is helpful, and someone can come to my rescue. Also I know my brakes are well worn, DBA T2s and Hawk Pads are sat upstairs waiting to be fitted Thanks Edited August 9, 2017 by Mark350Z Quote
