Home Heating Help Required!
Stew
Help!
I'm currently getting a kitchen installed, yesterday the sparks came in to move plugs about and wire up new appliances etc.
They switched off the power and when it came back on the central heating controller wasn't working normally! It can be switched on but I've lost all timer capabilities for some unkown reason.
It's a Danfoss SET1E. It currently displays n05 on the screen no matter what I press! I have had a quick scan on the net but can't find anything!
PLEASE HELP!
Stew when you say Central heating controller - you mean the timer ??
They should not have touched anything there should they????
No flow charts for error analysis in the instructions for your boiler? They usually have a flow chart for you to follow for such events?
I would be tempted to reset the electricity again by switching off the mains or at least the power to the controller? See if that does anything?
I found this forum to be useful with my Baxi boiler recently?
http://www.diynot.com/forums
Hope this helps?
IMPORTANT
If the SET1E is ever disconnected from the mains the display
will go blank but the unit will keep your programme time and
settings for up to 10 hours.
When power is restored the unit will continue to function as
normal.
For power cuts or disconnections of greater then 10 hours, when
mains power is restored you must reset the unit (see page 15).
This will reinstate the factory preset programmes and set the
time of day to noon.
Got that from http://www.danfoss-randall.co.uk/PCMPDF/8656.pdf
I'm a sparky and I can't see that they'd have had the power off for more than 10 hours but it's worth a shot. There will be a pin sized reset switch somewhere on the unit, try that and see if it resets to factory programs. If it doesn't take the unit off the wall and check on the PDF to make sure the connections are as they should be. Unless they've moved it from the wall these should be as they were before they came to your house. Failing that ring 'em up and tell them to come back 'cos it was working before they came :thumbs:
I wondered if the timer circuit had screwed up.
I'll have a look. The timer wasn't touched as it's in my study/cats bedroom.
If all else fails I'll unplug it for more than 10 hours and see what happens!
Thanks for the info!
Fixed. B)
Just to rub it in Stan - My house is toasty when I want it to be now! :lol:
I just did a hard reset and the fault cleared. Cheers Macca for finding the manual that I couldn't! :teeth:
