leebottrill Posted August 7, 2017 Share Posted August 7, 2017 Hi guys I had my new clutch fitted today and I've got a couple of small problems. Firstly my car is idling very low to the point where when I start it up it will idle so low it will stall. My mechanic has been looking around and seems to think that the car would relearn the correct idle amount. Has anybody had this problem when fitting a new clutch? I've fitted the Xtreme clutch kit. Mechanic did a smoke test to check for any leaks in the air system and there were none. Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted August 7, 2017 Share Posted August 7, 2017 Try the idle relearn procedure in the guide section. Was the throttle body off at all? Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 7, 2017 Author Share Posted August 7, 2017 I can't see where the guide section is? I'm not sure about the throttle body tbh! The car seems to drive well though. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 7, 2017 Author Share Posted August 7, 2017 Got it! Reset done but still stalling on start up without a throttle blip! Quote Link to comment Share on other sites More sharing options...
Redsky Posted August 7, 2017 Share Posted August 7, 2017 I know it sounds dumb but im only saying because i was doing it myself. Are you giving the fuel pump a second or two to prime? When i first got my Zed i was turning all the way to ignition right away and wasnt entirely sure why my engine was really struggling to startup. Doesnt seem to matter as much in small displacement cars but my Zed utterly hated it. Sorry if its a dumb suggestion xD Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 7, 2017 Author Share Posted August 7, 2017 Well I've had the car for 3.5 years with no problems, and after a clutch fit it's doing it. So it has to be something related. By prime you mean half twist the ignition for a sec? Quote Link to comment Share on other sites More sharing options...
Redsky Posted August 7, 2017 Share Posted August 7, 2017 Yeah so when i first got the car i was jumping straight to ignition so the 3rd click. Found out you are supposed to sit on the 2nd click for a second to get power to the pump, pump gets up to pressure then you can start the car. Ive had no issues starting since I started doing that, it used to struggle a lot when i started it right away im assuming because it was essentially running low pressure for a second and the air fuel mix was wrong. Im not a mechanic though so I could be entirely wrong. Although another entirely random idea could it be the sensor that detects if the clutch is depressed? Since it needs to be down to start the car? Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 7, 2017 Share Posted August 7, 2017 Flywheel misaligned? Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 7, 2017 Author Share Posted August 7, 2017 My mechanic said it was really difficult to misalign the flywheel as there was only one position it could go in. He seemed to think he definitely got it right but how can anybody be sure of that? God what a nightmare this is! Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 8, 2017 Share Posted August 8, 2017 I would imagine the symptoms of a misaligned fly in relation to the crank sensor would cause the car to misfire and possibly go into limp mode. If your not having any issues like that it may be aligned properly as he says. I have heard of lightened flys causing issues on other cars but not on Zs. If the CPS was damaged I would imagine the same issues with misfire or limp would rear up. If the only thing worked on was the clutch the only things I can think of is a pressure leak from the exhaust manifold end or misaligned fly. Hopefully you get it sorted, I'm sure someone with more knowledge than me will offer advice. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 8, 2017 Author Share Posted August 8, 2017 Ah. Well my battery was knackered so that was also replaced! I'm wondering if it was that? The car is running well and the clutch feels great (heavier than before) I have done the idle relearn so I'm going to drive it for a while and see if it improves. If the flywheel was misallined would the car be driving badly? Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 8, 2017 Share Posted August 8, 2017 I never found any issues when I replaced my battery aside from the fact one of my windows needed a reset as I left it open at the time. If you have a lightened fly that might affect the idle initially but unlikely, tinkering with the throttle body itself usually requires a relearn but not replacing a battery. So all is running fine now you've done the relearn? Like I said a misaligned fly would make the car run rough generally so that's probably OK if it does idle OK and run fine. Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 8, 2017 Share Posted August 8, 2017 I don't know much about aftermarket flys tbh, the OEM one I had put on had one screw hole a slightly different size which fitted over a pin on the face plate to ensure it was on the right way. Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted August 8, 2017 Share Posted August 8, 2017 There should be absolutely no idling issues following a clutch change. That said, you do have to remove the exhaust. Make sure that the Cat sensors are connected correctly and were not damaged in the process. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 9, 2017 Author Share Posted August 9, 2017 My biggest fear is that the flywheel is misaligned and they have to drop the whole gearbox. any other problems can be relatively easily resolved. That said it would still be nice to know. I have done the idle relearn but the car is still idling low and stalling when I first start it up. I'm going to drive it until the start of next week and see if it improves if not I'm going to dump it back in with the mechanic and let him deal with it. Can i just clarify that a misallined flywheel will result in a badly running engine? Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted August 9, 2017 Share Posted August 9, 2017 it would be really hard to misalign the flywheel to be honest and it probably wouldnt start and if it did it would run really crappy. did you do the ecu reset aswell?sometimes the relearn resets take a few attempts to get right and work properly 1 Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 9, 2017 Author Share Posted August 9, 2017 I did, but I have no idea if I did it right. How do you know if you have done it correctly? Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 11, 2017 Author Share Posted August 11, 2017 After doing a bit of research I think my idle issues are actually down to the fact I had my battery replaced. Prior to my car breaking down the battery was running down all the time and it ran flat when I did breakdown. The car has not stalled for the last two days when turning it on so I'm hoping that the idle relearn is relearning. The clutch actually feels really nice to drive despite it being slightly heavier than the previous one. Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted August 11, 2017 Share Posted August 11, 2017 Glad it seems to be sorted. It was probably resetting the idle every time it ran out. Weird though I've had batteries die on the zs and not had this issue. Hope it doesn't come back! Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 11, 2017 Author Share Posted August 11, 2017 Well I'm not sure it's sorted yet! It's still blipping very low when I start it up! I'm going to drive it for a week and go from there. I must admit the car does sound slightly different since the new clutch. More grungy! I'm not sure if that's normal either! Quote Link to comment Share on other sites More sharing options...
catman Posted August 13, 2017 Share Posted August 13, 2017 Sounds like you have an air leak somewhere. Tim Quote Link to comment Share on other sites More sharing options...
leebottrill Posted August 17, 2017 Author Share Posted August 17, 2017 Hi guys. So a week on and the idle issuers have cleared up. It seems the car does relearn over time. I have a couple of other questions regarding the new clutch which I'll move to a new chat! Thanks for your help! 1 Quote Link to comment Share on other sites More sharing options...
