4K1R4-350Z Posted July 26, 2017 Share Posted July 26, 2017 Hey guys, after the few weeks off the road due to the fuel tank fiasco, my Battery is dead as dead can be.. (wasn't in a good place before hand this was just the straw that broke etc...) Had to jump start everyday this week to get to and from work... seriously uncool..!! Anyway.. upon fitting the new battery (Bosch s5 008 96 which is BRILLIANT by the way cranks so fast it's epic!) I found the old battery wasn't locked down as it should be and in turn couldn't lock down the new battery.. The parts of the bracket I have just does not fit to the car, hook in the bottom then the peice over the top.. but nothing to lock into.. These are the parts I have in pic attached.. I feel there is something missing from the back (nearest the windscreen) am I right?? Thanks!!! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 26, 2017 Share Posted July 26, 2017 You will require a 50mm threaded hook for the rear. Probably hiding under the new battery. Quote Link to comment Share on other sites More sharing options...
4K1R4-350Z Posted July 27, 2017 Author Share Posted July 27, 2017 Cheers, thought as much. I checked when cleaning out the battery bay but couldn't find anything.. Don't happen to have one up for grabs do you?? Cheers Alex! Quote Link to comment Share on other sites More sharing options...
mr v6 Posted July 27, 2017 Share Posted July 27, 2017 19 hours ago, ZMANALEX said: You will require a 50mm threaded hook for the rear. Probably hiding under the new battery. As was the case with mine. Lazy fitter from a previous change. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 28, 2017 Share Posted July 28, 2017 16 hours ago, 4K1R4-350Z said: Cheers, thought as much. I checked when cleaning out the battery bay but couldn't find anything.. Don't happen to have one up for grabs do you?? Cheers Alex! Yeah, I will have one but you would be cheaper just picking one up from Nissan as I would have to charge you P&P. Quote Link to comment Share on other sites More sharing options...
