CO emissions failing
Posidrive
Just in case anyone has any ideas here's a bit more info
Problem at idle after starting the engine from warm with idle at about 750 rpm
The front bank of o2 sensors (both sides) continuously read rich and the rear bank lean
Front left hand o2 sensor has constant voltage of 0.28 V with occasional fluctuation to 0.29 V. Right hand sensor has same general but fluctuation is between 0.36 and 0.37 V
In case it helps anyone in the future, just had her smoke tested. Leak somewhere in the line that recycles the fuel tank vapor vent back to the engine. Plugged it temporarily and emissions spot on.
Suspect that the O2 sensors are a badly fouled and a little lazy though, these are the originals after almost 160k
1 hour ago, Jay84 said:
:lol: Glad to have them on board lol:lol:
Legit Nissan contact number... Well, NissanGB is a member since 2012, only 2 posts so far....Nissan must be desperate........or someone just got bored........or someone found a user name and password :surrender:
2 hours ago, Posidrive said:
Bosch part seems to be OE BOSCH 0258007240
Anyone installed one of these?
easy to change just a bit awkward to get to, get a proper  o2 sensor socket it will make it a lot easier as they tend to be a bit tight
