The complete knocks'n'noises thread...
ZedGreg
After having the car for just over a year now and experiencing some of the different wear-related noises, i thought it'd be a good idea to start a thread where we can explain various noises and the possible culprits.
I've found some are easy to find, other's not so.
The aim of the thread is to essentially provide a list of the common areas to explore when trying to locate a noise.
Please add to it or edit where you see fit.
Clicky axle - occurs when coming off or on to the accelerator - a sort-of clunking noise - search for clicky axle fix.
Banana/compression arm - a knocking when going over bumps - bush failure, replace bush or entire arm.
Drop links - a knocking noise when going over bumps - joint failure, replace drop links.
