Creaking clutch - now unbearable
Treybleed
Hey guys,
Got the unbearable squeaky/creaky clutch pedal and looking for some advice from others experience, I have seen other posts but I have tried the whole spraying the pivot bearing and achieved no results.
Cold - Can just feel the creak and squeak, its bearable.
Hot/warm - Super loud squeak and creak can be felt across the whole pedal travel.
I had my clutch changed about 5000 miles ago (extreme clutch + smf) BUT didn't replace the pivot bearing (i know), just had it repaired by horsham instead as mine is an 03 and has the longer style bearing and couldn't get hold of 1 in time. Could this cause the creak feeling / squeak? or do i maybe need a new clutch fork? can they cause this issue?
I have greased the spring etc on the pedal in the car, no noise or creaking is coming from there, its all under the car.
Thanks in advance !
Oh really, that will cause a horrible creaking feeling down the pedal as well?
I'll get it up on the jacks and get someone to push the clutch pedal down and see if I can hear it coming from the slave!
Thanks!
