Colin747 Posted July 17, 2017 Share Posted July 17, 2017 Just wondering how serious rust in this area is or if should be an easy enough fix? I was thinking about replacing the rear wing to deal with arch rust so would this section also be replaced on the new wing? Would there ever normally be rust on whatever metal is underneath the wing if that makes sense? Once you cut the old wing off to replace it is there likely to be rust that needs treated there? Quote Link to comment Share on other sites More sharing options...
