Declangibbs Posted July 12, 2017 Share Posted July 12, 2017 Hi I have a strange problem with my 350z. basically every now and again I will get in the car, turn the key to position 2 and everything lights up and all electrics work but then the car won't start. it won't even crank over or any noise just nothing. any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted July 12, 2017 Share Posted July 12, 2017 Daft question I know ! you are pushing the clutch down ? Quote Link to comment Share on other sites More sharing options...
PPod Posted July 12, 2017 Share Posted July 12, 2017 whats your power voltage at on your dials ? If its below 10v it won't start but all electronics still work. Quote Link to comment Share on other sites More sharing options...
Jay84 Posted July 12, 2017 Share Posted July 12, 2017 I was thinking the same as @SHEZZA, and if you are it could be a loose connection on the clutch pedal switch. Quote Link to comment Share on other sites More sharing options...
gillywig2 Posted July 12, 2017 Share Posted July 12, 2017 Faulty/dirty clutch pedal switch. That was my problem a couple of years ago. Quote Link to comment Share on other sites More sharing options...
Declangibbs Posted July 12, 2017 Author Share Posted July 12, 2017 Yep clutch pedal being pressed. Okay thanks is it a hard job? Quote Link to comment Share on other sites More sharing options...
Declangibbs Posted July 12, 2017 Author Share Posted July 12, 2017 Just seen on another thread that you can adjust the switch. Will have a go at that tomorrow. is there any other things it could be ? Quote Link to comment Share on other sites More sharing options...
biggles Posted July 12, 2017 Share Posted July 12, 2017 Do the dash lights dim when trying to start? If so, could be loose battery connections not allowing starter motor to draw enough current and crank the engine. Quote Link to comment Share on other sites More sharing options...
Declangibbs Posted July 12, 2017 Author Share Posted July 12, 2017 Will check tomorrow but I know for a fact the terminals are all connected tight. im starting to think it could be starter solenoid. just seems strange that if I leave it for a minute it will start fine Quote Link to comment Share on other sites More sharing options...
glrnet Posted July 13, 2017 Share Posted July 13, 2017 Check the earth conenctions too. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted July 13, 2017 Share Posted July 13, 2017 I had a poor connection on the bulk head battery earth lead Quote Link to comment Share on other sites More sharing options...
Declangibbs Posted July 13, 2017 Author Share Posted July 13, 2017 Think I've got it sussed. just looked at the clutch pedal and I can see the sensor and it's coated in blue electrical tape. Guessing someone has bypassed the sensor poorly. guess I've found this afternoons job! Cheers guys Quote Link to comment Share on other sites More sharing options...
Ebized Posted July 13, 2017 Share Posted July 13, 2017 5 hours ago, glrnet said: Check the earth conenctions too. +1 particularly the engine to chassis that has previously been reported as an issue on a few occasions. Quote Link to comment Share on other sites More sharing options...
