giec Posted July 5, 2017 Share Posted July 5, 2017 Hi I am looking for a new engine to Nissan 350z 2004 , Can I put the engine from earlier models as well ? Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 5, 2017 Share Posted July 5, 2017 A 2004 350Z will have the earlier engine in anyway, the DE. If you mean can you fit the later Revup and HR engines then the easy answer is no, not as a straight swap. You need a fair amount of modification to the wiring loom (and the exhaust in the case of the HR) plus ECUs which makes it cost-prohibitive. Welcome along btw 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 5, 2017 Share Posted July 5, 2017 1 hour ago, giec said: Hi I am looking for a new engine to Nissan 350z 2004 , Can I put the engine from earlier models as well ? The simple answer to your question is yes. Quote Link to comment Share on other sites More sharing options...
giec Posted July 5, 2017 Author Share Posted July 5, 2017 3 hours ago, Ekona said: A 2004 350Z will have the earlier engine in anyway, the DE. If you mean can you fit the later Revup and HR engines then the easy answer is no, not as a straight swap. You need a fair amount of modification to the wiring loom (and the exhaust in the case of the HR) plus ECUs which makes it cost-prohibitive. Welcome along btw Thanks Ekona . Yes , I ment newest models of course . Quote Link to comment Share on other sites More sharing options...
