265/40/18 square
KuroKiddo
Before I spend a lot of money for a set of 265/40/18 AD08R square set up can anyone confirm it's within the 3% TC/VDC limit and therefore I won't have any problem with it? Thanks
edit also how about 265/35/18 square? Won't mind trying the Nangkang NS2R
Edited by KuroKiddo
A square tyre setup will make the VDC far more likely to intervene (like much, much more) as you'll have altered the balance front to rear. This will make the car far more likely to oversteer, so you'll probably want to run with the VDC off permanently to stop it ruining all the fun.
Unless you know what you're doing and are happy for a tail happy car, most people are better off running a staggered tyre setup. You can still do that on square setup wheels, if that's the goal. Not passing judgement on driving skills, just saying what works for the majority. :)
  • 2 months later...
