Is this a full list of what I need to do?
Hey all =)
I've been studying the service history for my vehicle, and although it has all of the stamps I think I am missing some paperwork from the previous owner, so I am not 100% on what has and hasn't been replaced at certain intervals.
To that end, and because it is now service time, I've decided I am going to do everything at once, so that I will know when everything next needs replacing.
Can anybody indicate whether or not this look like a full list of what I would need to change? Have I missed anything? Is there anything there that won't need doing? Is there anything else I should consider doing as I will be attempting to service it myself? Does anything else need lubricating? Brake fluid & power steering fluid have been done recently so have been left off of this list.
Engine Oil
Oil Filter
Air Filters
Gearbox Oil
Clutch Fluid
Diff Oil
Coolant
Alternator & AC belts
Spark Plugs
If I can get confirmation of whether this is all I need to do then I can research the individual parts required from there and stop bothering you good folk =D
This is a full P3 kit list from Clark Motorsport on here:
I am assuming that your 350Z is VQ35DE with a 6 speed manual transmission and a VLSD:
Spark Plugs should be changed at 5 years or 54,000 miles
Antifreeze should be changed at 3 years or 36,000 miles
Transmission fluid should be changed at 3 years or 36,000 miles
VLSD fluid should be changed at 3 years or 36,000 miles
Front engine belts should be changed at 3 years or 36,000 miles
Here is a general price list for you.
The items marked # are required for a P3
The items marked ## are advisory depending on the age and mileage of your car.
Engine Oil Motul 5W30 Fully Sync. £35.95 #
6 sp Genuine Nissan Manual Gearbox fluid £39.95 ##
60ml DC Molyslip for Gearbox £12.50 ##
Auto/Triptronic Gearbox J fluid £187.00
Diff. fluid (Viscous) VLSD Genuine Nissan £25.36 ##
PAS fluid Genuine Nissan £12.50 ##
Brake fluid Motul RBF 600 £14.95 x 2 #
Or Brake fluid Motul RBF 660 £18.95 x 2
Clutch fluid Motul RBF 600 £14.95
Oil filter Genuine Nissan (White) £8.64 #
Crush washer £1.95 #
Heavy duty Magnetic sump plug £24.95
6 x Denso Iridium Spark Plugs £49.95 #
Panel Air filter OEM Nissan £12.95 #
Performance Panel Air filter HKS £ 32.50
1 x Set of Gates Belts £29.95 ##
2 x Belt tensioner nuts £1.95 each ##
2 x Pre mix Genuine Nissan Coolant: 5Lt. £19.99 each (Good to -38 degrees C) #
Thanks, that's really helpful!
Does it differ at all for the HR model besides the 2 air filters? I'm assuming all of the belts and things are the same?
Thanks! Good thing I asked :lol: I'd have ended up with 2 belts and been searching for where the hell the other goes ^_^
Just contact the Traders on here, they can send you everything you need. All tried and tested and the prices are right :)
The above is a service price list which I compiled 6 years ago, so you may find that there has been some movement with the pricing structure.
Just give Ewen or Rich a shout at CMS for pricing confirmation.
Alex. :)
Thx Alex =)
On the servicing checklist I found it mentions lubricating/greasing all sorts of parts; do people normally do all this when they service their own vehicles?
Sent from my SM-G935F using Tapatalk
I compiled a list here, contain links to the traders on here and shows the difference between HR & DE and links to help guides.
I updated it fairly recently, it may not be obvious but there are 2 tabs.
http://www.350z-uk.com/topic/31107-service-schedule-for-a-350z/page__st__60#entry1736391
Let me know if you find anything wrong with it.
Thanks Stu, that's the one I have, I wondered if anybody else lubricated / greased all of those parts or whether they leave them? I can follow instructions to change things myself but wouldn't know what to keep an eye out for.
Thanks Randy, I'll check out your link =)
