Olly350z Posted June 17, 2017 Share Posted June 17, 2017 Im looking to buy coilovers on payday, pretty much decided on a brand, Jerricks at Meister R Used his coilovers for years on the civic and had nothing but good things to say, so I figure go with what you know! They also retain the OEM setup with the bucket spring I have a few question's though. When it comes to lowering, how exactly does that work at the back? Is the height adjusted by the spring or is it at the shock? From reading various bits online, it would seem 25mm is the max before needing camber arms, and even that is pushing it. I know I'll need these for the perfect GEO but all in time. What should I have ideally with the coilovers to go on? Am I right in saying the toe bolts can be a pain coming undone? Any problem areas to watch out for when fitting? Thanks in advance Quote Link to comment Share on other sites More sharing options...
davey_83 Posted June 17, 2017 Share Posted June 17, 2017 Be sure to get the damper adjustment extenders also for the rears. Yes right height adjusted from the springs rear, not dampers as per the front. Also had a set of MeisterR from Jerrick on a previous car *Almera GTi - loved em. Quote Link to comment Share on other sites More sharing options...
BobbyZ Posted June 17, 2017 Share Posted June 17, 2017 My rear camber is just outside OEM spec, and I'm only lowered 14mm at the back. I think it varies a bit from car to car how much you get get away with before needing camber arms. Quote Link to comment Share on other sites More sharing options...
Olly350z Posted June 30, 2017 Author Share Posted June 30, 2017 So thought Id update this, took the plunge today and ordered them from Meister R. Whats this about needing different toe arm bolts? Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted June 30, 2017 Share Posted June 30, 2017 Just remember to keep the rake ratio between front and rear (so rear slightly higher) close-ish to stock. FSM 2004 FSU Page 21 Coupe Front: 683mm Rear: 706mm (Difference of 23mm) That's from the ground to the wheel arch. Quote Link to comment Share on other sites More sharing options...
