hairyman68 Posted June 15, 2017 Share Posted June 15, 2017 Hi guys, last yr i upgraded the front speakers but now one of the rears has stopped working. I was wondering has anyone stripped the rears out..? Or could you cut through the front to remove them then just fit new mesh over the front..? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 16, 2017 Share Posted June 16, 2017 You will have to remove the rear trim to gain access to the speaker bolts. The speakers are much bigger than the grills so a huge hole would have to be cut to get them through. The rear trim is quite easy to remove successfully if patient. If you partially open the roof and peel back the vinyl from within the roof aperture area, you will see how it all comes together. 1 Quote Link to comment Share on other sites More sharing options...
hairyman68 Posted June 16, 2017 Author Share Posted June 16, 2017 Is it much of a job once under the vinyl ? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 16, 2017 Share Posted June 16, 2017 You can only view from under the vinyl. The speakers can only be removed from behind the seats once the trim is removed. Quote Link to comment Share on other sites More sharing options...
Philip stutts Posted September 21, 2021 Share Posted September 21, 2021 Is there a video showing how to remove the rear speakers from a 2008 350 Z roadster convertible Quote Link to comment Share on other sites More sharing options...
