Joseph350 Posted June 13, 2017 Share Posted June 13, 2017 Hi their I'm new to the 350z world.. I've owned my 350 convertible a month now it's a jap inport.. when I first got the car it was running abit flat.. So I replaced the battery It seemed to be running sweet for about 10 min then it started to miss fire So I replaced the spark plugs and the coils it then started to miss fire even more even on start up.. Obd scanner read p1051 which is air fuel sensor bank 2 sensor 1.. I couldn't imagine that to sensor to cause such a miss fire Any help would be great thanks Quote Link to comment Share on other sites More sharing options...
57jam89 Posted June 15, 2017 Share Posted June 15, 2017 Well if you have fault code then that's what the problem is. 1 Quote Link to comment Share on other sites More sharing options...
Jake.Lowther Posted June 15, 2017 Share Posted June 15, 2017 It will be the sensor if it's saying that's the issue, the sensor even stats what it does in the name. Air/fuel sensor meaning it has some contribution to measuring how the air and fuel is mixed. If it's faulty it could be causing the ECU to inject to much fuel thus causing your car to run rich and Miss fire. 1 Quote Link to comment Share on other sites More sharing options...
Joseph350 Posted June 15, 2017 Author Share Posted June 15, 2017 Yeah I understand that it's in the title, but It's just come up with a new code today p0350.. Which is coil ignition circuit problem.. Do you recon this could be the ecu.. Coils have just bin Changed .. Quote Link to comment Share on other sites More sharing options...
Beefy Posted June 19, 2017 Share Posted June 19, 2017 Coilpacks I imagine. I had the same issue, kept on running on 5 cylinders... Especially in the heat. Buy some splitfire coilpacks from Japan. Solved my issues. Quote Link to comment Share on other sites More sharing options...
Joseph350 Posted June 20, 2017 Author Share Posted June 20, 2017 It's funny you say that beefy!! That was the problem with mine.. Dodgey coil pack!!... my 350z is now running spot on.. Only problem is, the engine management light is still on.. Thank you too everyone for your advice it's bin much apriciated 😃 Quote Link to comment Share on other sites More sharing options...
