JimF Posted June 7, 2017 Share Posted June 7, 2017 I've recently bought a car that the previously 'detailing fan' owner ceramic coated (told by the dealer). Now I'm looking to debadge it (simple stick on badges, no pins) and I'm concerned that it will leave behind an image of the badges once the ars removed as that area has not been ceramic coated. Can I buff this out? The car is black if that makes a difference. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 8, 2017 Share Posted June 8, 2017 You can polish, but that'll remove the coating from the area as well. The immediate area is likely to need at least a quick polish though so there's little you can do to avoid that. Do you know which coating was applied and when? Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 8, 2017 Share Posted June 8, 2017 First thing I'd try and establish is whether it's actually coated or not. Quick wash will tell you that, massive difference between a waxed car and a coated one. Only way to tell if it'll leave a mark is to take them off and see. I agree with my learned friend above, probably going to need a polish regardless. Quote Link to comment Share on other sites More sharing options...
JimF Posted June 8, 2017 Author Share Posted June 8, 2017 Hmm right. Bit tricky then. No info regarding specifics on the "when and what" for the ceramic. Could just be waxed but not sure. How would I tell the difference? You says there's a big difference between ceramic coated and waxed, but I don't have anything to compare it to. Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 8, 2017 Share Posted June 8, 2017 YT some videos, even the best waxes don't compare to the sheeting effect of water over a coated surface. Quote Link to comment Share on other sites More sharing options...
JimF Posted June 8, 2017 Author Share Posted June 8, 2017 Will have a research Quote Link to comment Share on other sites More sharing options...
peggers350 Posted June 12, 2017 Share Posted June 12, 2017 when i detail a car i always give my car a good DA'ing to get all the swirls out but you can apply some swirl fillers such as prima amigo or poorboys black hole before hand. with ceramics such as gyeon an carpro cquarts there forgiving to the novice on the application an removal side an are pritty decent products aswell. i swear by the cquarts as the longevity is about a year an it does exactly what it says on the box an you get alot of product for the money Quote Link to comment Share on other sites More sharing options...
nipwahh Posted August 15, 2017 Share Posted August 15, 2017 I would imagine there will be a patch left from the uncoated area underneath the badge, it would require the coating to be removed from the panel, if it was home applied, machine cutting would remove it, you can then reapply the coating. Quote Link to comment Share on other sites More sharing options...
