Destin Posted May 31, 2017 Share Posted May 31, 2017 Hello. I've got 2003 Zed, it has xenon lights. It's a JDM import so it has 6 PIN. I bought left xenon headlight from ebay(due to accident it was crashed), and it has 8 pin. It says that it fits 2002-2006 so it's not bi-xenon. How should I connect it? Have anyone got diagram which could help me? Thank you, Damian. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 31, 2017 Share Posted May 31, 2017 I have 8 pin connectors in stock if required. Just drop me a pm if I can help you further. Alex. Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted May 31, 2017 Share Posted May 31, 2017 (edited) You're a lucky boy, I've been doing this research myself lately, mine's going in tomorrow (I;m having a pro do the splicing though, and I'm going the other way, I'm going FROM 6 to 8 pin. Worth mentioning there is no need to cut anything, the connector blocks can be disassembled and the entire pins moved from one block to another, for a very neat final result. You'll need the 6 pin off your old headlight, but basically, the following info seems to be complete, taken from the US forum. Also, be aware that in the Haynes manual there is a full wiring diagram. Let me know how you get on... You will cut the 8 pin off the head light... that will leave you with 7 wires Red Fat - Positive to ballest. Black Fat - Negative to ballest Skinny black - Common Ground for accesories lights Light Green - Positive High beam actuator Green/White Stripe - Positve for 4LEDs and corner running light That leaves solid blue and solid green... which runs to the same bulb. One is a running light(on when the headlights are on) and one is a brighter blinker. I forgot which is which but i dont use the running light. You can, but i think it looks cleaner without it. Power a 12 volt source to black and blue or green to tell which one is brighter. Also, i think because i disconneted one it made my blinker blink fast... but i kinda liked... helps since i switch lanes so fast edit (blue is the blinker + , i didnt use solid green.) Now.. your 6 pin harness... cut that off your old headlight... leave as much wire as you can. You will have: Red - Low beam positive ..... goes to Fat Red- powers ballest Black - Low beam negative - goes to Fat Black powers ballest Light blue - high beam +... goes to light green - high beam actuator Green/black stripe - Blinker +... goes to green or blue... whichever is brighter. Green/White - Running light... goes to Green/White Skinny black - common ground to skinny black 8 Pin--------------6 Pin-------------------------Function Fat Red------------Fat Red-------------------- Ballest + Fat Black----------Fat Black-------------------Ballest - Skinny Black-----Skinny Black---------------Common Ground Green/White -----Green White---------------LED/Corner running lights Green Black------Nothing or Green/White -- Blinker running light Light Green ------Light Blue------------------High beam + Blue/Black--------Green Black---------------Blinker + Edited May 31, 2017 by Aashenfox Quote Link to comment Share on other sites More sharing options...
