StevoD Posted May 29, 2017 Share Posted May 29, 2017 Right so at teeside today I finished a run and come off throttle and the engine struggled to idle Got back to the pits and it idles at like 500rpm on 5.5 cylinders With maf removed it runs just as lump but at 1000rpm We unplugged each coil pack one by one it made no difference in how it idles No codes present Any ideas? Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 30, 2017 Author Share Posted May 30, 2017 Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted May 30, 2017 Share Posted May 30, 2017 I see you have a plenum spacer fitted. Make sure all the bolts are nipped up and there are no loose ones. Then spray a can of carb cleaner all over the throttle butterfly. Other than that is sounds ok apart from the obvious struggle as the revs drop low. Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted May 30, 2017 Share Posted May 30, 2017 (edited) I can't see vids til I get home. Does it seem like it's running richer? Lamda? Edited May 30, 2017 by Aashenfox Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 30, 2017 Author Share Posted May 30, 2017 (edited) just to add after shooting them videos and having a little rev it sat at around 700 rpm for about 10-20 minutes without dropping in RPM, Oddly the RPM drop when AC is turned on which is not what it used to do they used to raise a little. and although its idle speed is stable it still seems a bit unbalanced and the exhaust seems aweful poppy/rumbley than before but that might be me stressing out Why when ever i get a fault it seems to be one nobody has ever had before i dont know Edited May 30, 2017 by StevoD Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted May 30, 2017 Share Posted May 30, 2017 Poppy and rumbly sounds rich. Lamda (O2) sensor? Quote Link to comment Share on other sites More sharing options...
butter Posted June 2, 2017 Share Posted June 2, 2017 I had really rough idle at like 500rpm sounding like it would stall out, fine when driving. Ended up unplugging battery, cleaning throttle body out & then re-fitting it all. Runs perfectly since. 1 Quote Link to comment Share on other sites More sharing options...
