Air Con setting
heyho
My ait con works i.e. when on fully cold setting it is cold (very cold). But as soon as I even slightly move the dial I start to get warm air. And I mean even if I move it a fraction.
Anyone any ideas.
By the way is the air con condensor situated anywhere near the front passenger side wheel area o fthe engine. Only reason I ask is that I do get a little water (definately not any other fluid) on the floor when it is parked up.
If you've got climate control it will warm up quickly then just drop down again. So if you have it set to as cold as it'll go and the inside is 14 degrees (rough example), and you set it to 19, it'll blow hot to quickly raise the temp to the desired setting then should maintain it. However if it just keep getting hotter, then you may have an issue
