Clutch pedal play.
mr v6
Hi all,
Following on from this topic last year: http://www.350z-uk.com/topic/111333-wont-engage-gear-odd-clutch-pedal/
I had a failed CSC & it was replaced with a genuine Nissan part, all works fine. From cold you have full pressure on the pedal all the way to the floor. I did notice straight away (as you do in the hotter weather) that the pressure isn't as much, instead I seem to lose a bit of pressure for about 1" of travel. To explain it as best as I can, the firm travel I have from cold seems to get lost when hot & the first part of pressing the pedal feels like nothing apart from tension on a spring on the pedal somewhere.
  • 4 weeks later...
Today for the first time since having the new CSC installed 9 months (4500 miles) ago, the pedal stuck part way down. I left it & could still change gears as normal, but it seemed hydraulic pressure pedal travel as maybe an inch. It's got me worried that it may be failing so early.
How is the pedal in the hot on everyone elses Z? Do you get this, or do you have full pedal travel & pressure all the way from the top to the bottom?
Should have fitted an after market uprated CSC
However, even an OEM should not have "failed" already.
Best to take it to a specialist for a proper bleed as sounds like some air may still be trapped in the system.
You can stick with genuine Nissan at around £80.00 or aftermarket at circa £45.00.
I personally would go with genuine Nissan.
When I do the CSC delete, I always fit a genuine Nissan DE slave cyl.
However I would firstly eliminate air in the system before splashing the cash.
Thanks for the input Alex. As a matter of course, I've ordered a bottle of Motul RBF 660 & a Stoptech slave. I'll try the bleed with new fluid first. I'm going to use the bleeding method by blocking the cylinder as that seems to yield good results. If I start to get a mushy pedal from then on in, I'll swap the cylinder.
  • 5 weeks later...
I bled the system today using normal brake fluid. I went through exactly 300ml. Iwas told by a 'tech' (word used very loosely at work) to get a pipe with a small slit in it, that way it allows fluid out & no air in.. This didn't work, so had my dad come over & we did it the normal 2 man way. After a short time of dad having to pull the pedal up with his foot etc, we had a good pedal (I mean the normal pedal) after about 20 mins. I still have the same amount of pedal play as before. I'm starting to think it could be the master cylinder, purely because every now & again if I press the pedal I feel a little of the play go, then it comes back, plus the master is making a squeaking / creaking noise when the pedal is pressed. I also noticed the crappy Nissan insulation that's around the hydraulic pipe, it's a poor attempt at heat diversion. I ordered a 2" wide length of exhaust manifold wrap from ebay. I got rid of the standard stuff & wrapped the heat wrap around the braided line using cable ties every inch or so, just in case the fluid was boiling up, the standard heat wrap was all open bar a couple of cable ties in the wrong places.
Time will tell I suppose.
Can I just ask, if this problem continues, the next stop would be the master cylinder. Torqen shows a rebuild kit for the DE for just £27.62. Has anyone any experience fitting this kit & fixing their problem before forking out £100+ on a new master?
