scotzman Posted May 24, 2017 Posted May 24, 2017 Hi all, had a document where it tests the brakes or could have been brake booster test using ingition and brake pedal but have lost it and cheking all the how to's cant seem to find the procedure.... it worked good but forgot the procedure, anyone have it ? Thanks for your time Quote
Ekona Posted May 24, 2017 Posted May 24, 2017 Ignition off, pump the brakes until the pedal goes hard. Keep foot on pedal, it should stay hard. Engine on, foot still on pedal, it should sink until reaching a normal depressed position. If it sinks right to the bottom, you have an issue. Quote
scotzman Posted May 26, 2017 Author Posted May 26, 2017 Ignition off, pump the brakes until the pedal goes hard. Keep foot on pedal, it should stay hard. Engine on, foot still on pedal, it should sink until reaching a normal depressed position. If it sinks right to the bottom, you have an issue. Thank you sir. Quote
