camber arms- elongated holes?
LDUNKZ18
so my alignment was done today but due to it being on coilovers i now need adjustable camber arms, as the camber drivers rear wont set correct without affecting the toe, so if the camber is set fine the toe is out and vice versa.
question i have now is that ive read and seen on youtube folk elongating the holes on the subframe when fitting the arms. is this essential? surely the arm has the adjustment needed or is this only needed when setting the camber when really low and using on track or for drifting?
Elongating the subframe hole is for toe, so if you need more than the standard eccentric bolt\nut then yeah do it and fit the Eibach bolt.
Sounds like you are staying within the recommended factory settings so don't bother with it (imho).
But having the adjustable camber arms is worth it (with locking washers).
