Humming, after install to car stereo
sebZman
Possibly a bad earth connection ?
It does not change anything
I took good mass
I think the noise is because the car radio continuously powers the amplifier
The OEM must power the amplifier when there is music
Maybe my theory is wrong :/
Pretty standard that the amp has continuous power when the headunit is on.
When you say it does not change anything, what do you mean ? Did you disconnect the earth cable while powered and no change ?
Did you earth it as shown in the instructions you posted ? Try cleaning the surface you earth to with a bit of sand paper and try again, most of the time a buzz is a bad earth connection somewhere, could also be a bad speaker connection too though. But the earth is easier to trace and check.
Edited by Willsy1980
Yes, I connect the ground wire to two different places
Disconnected reconnected and this does not change anything
It's a common problem after new head unit. It won't be a bad earth. Do the buster hack/ buster mod. There's a few threads on it. Worked a treat
Sent from my SM-G928F using Tapatalk
the buster hack/ buster mod? Sorry I do not understand
There was a link in the guide you used for the install, here: http://www.350z-uk.com/topic/58947-reduced-sound-out-put-after-replacing-oe-bose/
Yes, I have respecting exactly the guide
There was a link in the guide you used for the install, here: http://www.350z-uk.c...lacing-oe-bose/
  • 1 month later...
