57jam89 Posted May 17, 2017 Share Posted May 17, 2017 Hi all, I'm thinking of fitting the oil pressure and volt gauges from a Z to my skyline 350gt. Does anyone know if these gauges connects to body control unit or straight to power supply and pressure sensor on this of engine block? Thanks. Quote Link to comment Share on other sites More sharing options...
Dicky Posted May 17, 2017 Share Posted May 17, 2017 As far as I can tell from the circuit diagrams they are not driven directly from sensor outputs. The oil pressure sensor output goes into a "Triple meter cpu" then on into a "Unified meter and A/C amp module". The voltmeter is also driven from the output of the Triple meter cpu which also appears to be driven by a output of the "Unified meter and A/C amp module". So no direct signals from the sensors......as far as I can tell. Hope this helps! Quote Link to comment Share on other sites More sharing options...
57jam89 Posted May 18, 2017 Author Share Posted May 18, 2017 Hi, yes this helps. Aftermarket ones then! Thanks. Quote Link to comment Share on other sites More sharing options...
