barnacle bill Posted May 13, 2017 Share Posted May 13, 2017 hi new on here. anyone know if you can and how to adjust rear hood pull down clip, as it does not pull the hood down tight and so the rubber does not seal completely. thanks mark Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted May 13, 2017 Share Posted May 13, 2017 to the club 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 13, 2017 Share Posted May 13, 2017 (edited) to the forum, and in answer to your question, just adjust the striker plate which is fitted to the front carbon composite panel. Edit: are you referring to the bonnet or the boot ? Also coupe or roadster ? Edited May 13, 2017 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Share Posted May 13, 2017 Do you mean this adjustment? It should cause the boot (read hood?) to be pulled closed tighter... Quote Link to comment Share on other sites More sharing options...
barnacle bill Posted May 13, 2017 Author Share Posted May 13, 2017 hi all , this is a roadster and it is the clip that pulls the rear of the roof down to seal it to the lift up flap Quote Link to comment Share on other sites More sharing options...
barnacle bill Posted May 13, 2017 Author Share Posted May 13, 2017 to the forum, and in answer to your question, just adjust the striker plate which is fitted to the front carbon composite panel. Edit: are you referring to the bonnet or the boot ? Also coupe or roadster ? hi it is a roadster, and i am referring to the rear roof clip that pull roof back of the roof down to seal it to the lift up flap Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Share Posted May 13, 2017 Ahh, that sort of hood, my bad. Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 13, 2017 Share Posted May 13, 2017 How refreshing🙂 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted May 13, 2017 Share Posted May 13, 2017 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 13, 2017 Share Posted May 13, 2017 to the forum, and in answer to your question, just adjust the striker plate which is fitted to the front carbon composite panel. Edit: are you referring to the bonnet or the boot ? Also coupe or roadster ? hi it is a roadster, and i am referring to the rear roof clip that pull roof back of the roof down to seal it to the lift up flap Still not quite sure what you are trying to say, can you rephrase that please. Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Share Posted May 13, 2017 I assume the lift up flap is the bit marked with a blue cross and the bit circled in purple is the clip (or whatever that clips into). So whatever holds the back of the roof down and in place. Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted May 13, 2017 Share Posted May 13, 2017 (edited) If on the pic above you mean the blue X lid seating down on to the rubber ? There must be either adjustment in the 2 catches on the post things or on the strikers on the flip up lid. The one in the above picture looks different to mine, I'll pop it open tomorrow if it's not raining and have a look. Or Alex will most probably know Edited May 13, 2017 by Willsy1980 Quote Link to comment Share on other sites More sharing options...
barnacle bill Posted May 14, 2017 Author Share Posted May 14, 2017 I assume the lift up flap is the bit marked with a blue cross and the bit circled in purple is the clip (or whatever that clips into). So whatever holds the back of the roof down and in place. hi yes these are the bits i am talking about, on mine the rubber is on the roof not on x. i have looked into the inside of x but cannot see how you can adjust it Quote Link to comment Share on other sites More sharing options...
barnacle bill Posted May 14, 2017 Author Share Posted May 14, 2017 If on the pic above you mean the blue X lid seating down on to the rubber ? There must be either adjustment in the 2 catches on the post things or on the strikers on the flip up lid. The one in the above picture looks different to mine, I'll pop it open tomorrow if it's not raining and have a look. Or Alex will most probably know hi mine is slightly different to above but same idea. i have looked into inside of lift up flap, but adjusting it is not obvious. ps i am not unfamiliar with mechanics. Quote Link to comment Share on other sites More sharing options...
