Strudul Posted May 12, 2017 Share Posted May 12, 2017 (edited) Was adjusting my shift plate and noticed this cable isn't connected to anything. As far as I can tell everything works (inc heated seats and seat position / recline motors), and I have the GT pack with all(?) the extras except Sat Nav. Is this just a generic loom with spares for other stuff or am I missing something? Is it used for automatics only and / or the snow mode switch (blank one that I'm missing)? Edited May 12, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
mr v6 Posted May 12, 2017 Share Posted May 12, 2017 Given it's location it surely must be used for the slush box? 1 Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 12, 2017 Author Share Posted May 12, 2017 Potentially. As I say, the alternatives I can think of would be the snow mode switch or pre-facelift hazard button: Quote Link to comment Share on other sites More sharing options...
Sargara Posted May 12, 2017 Share Posted May 12, 2017 Part of the bluetooth module in the armrest behind the gearbox and the cables have moved forwards perhaps? 1 Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 12, 2017 Author Share Posted May 12, 2017 Ooh, haven't checked the BT works. I'm sure I remember seeing the light flash, but I've never actually used it. Quote Link to comment Share on other sites More sharing options...
Sargara Posted May 12, 2017 Share Posted May 12, 2017 I dont have the module either but it seems all the cars have the cable prep for them regardless of it being fitted or not. I know i've got some wiring loom knocking around back there too. Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 12, 2017 Author Share Posted May 12, 2017 (edited) Though the cable is / was clipped into the plastic above it and is facing sidewards (kinda how it is now), which would imply something towards the front and passenger side of the car rather than the rear / left. Edited May 12, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 13, 2017 Share Posted May 13, 2017 They look like the seat vlips for the motor - but you would have noticed that ??? They don't belong there though not seen that type of clip in that location on another one before. 1 Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Author Share Posted May 13, 2017 (edited) They look like the seat vlips for the motor - but you would have noticed that ??? They don't belong there though not seen that type of clip in that location on another one before. Are you saying none of those cables belong there or just the one that isn't connected? The little grey clips on top clip into the plastic holes above for all of them, so they seem to have been designed to be there... (first picture shows the holes quite well) There doesn't seem to be much give in them either, whether this is because they are trapped or just don't have any slack to pull on I don't know. Suppose I should dismantle things and do some investigating, but it looks like a lot of effort and I'm assuming it will need the entire centre tunnel removing. Edited May 13, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
evilscorp Posted May 13, 2017 Share Posted May 13, 2017 My mind has gone blank, does the larger one somehow connect to the esp module near the back of the transmission tunnel? It was only a few weeks ago I was trying to rip it all out lol. Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Author Share Posted May 13, 2017 Found this picture of an S14, so I'm going to put my money on it being a generic cable harness and the spare is for an AT: Best I could find for a Z was this thread, but couldn't match up the cable and can't find any pictures from a facelift. Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 13, 2017 Share Posted May 13, 2017 Your wiring loom must have been moved around as the one with the gray clip that is disconnected and the the other with the grey clip should not be there, my guess is that the loom has been moved around at some point and just put back in a bit out of line, strip the cover off and have a look see whats what. Ref other comment above, yes you do get wires from the standard looms that are just left un-connected if that car does not have the relevant feature 1 Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Author Share Posted May 13, 2017 Had a play, couldn't get the centre tunnel all the way out because the headunit and handbrake are in the way, but I managed to lift it enough to see what's going on. Quote Link to comment Share on other sites More sharing options...
Strudul Posted May 13, 2017 Author Share Posted May 13, 2017 (edited) Can't see how it could go anywhere else unless maybe it can tuck under the carpet?? http://www.ebay.com/...NBXWOn2&vxp=mtr Edited May 13, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 13, 2017 Share Posted May 13, 2017 A guess but I think it should be clipped along the tunnel maybe under the carpet not had one-off in a few weeks Quote Link to comment Share on other sites More sharing options...
