[SOLD]FS: HKS GT GTM modded Supercharger kit for 03-06 350z + Uprev Tuner with MAF GT
Dr.Factory
Price: SOLD
Location: Italy, will ship worldwide included in the price.
Condition:
-Uprev tuner is brand sparkling New ( just connected ONCE to the car for testing it, license is back on the cable ) bought new 1 month ago from Abbey Motorsport UK while the Maf GT is used but perfectly working.
-The Supercharger kit was bought new from Nengun.com about 1 year ago, professionally installed and used for less than 4000 miles on the street, so it is in great shape , actually as good as new, both visually and mechanically .
I can show buying receipts.
I will only accept paypal payment for both yours and my peacefulness.
Contact me at my email or pm for any info, price is slightly negotiable ! :)
Description and Images:
-Uprev Tuner Cable with License. You all know everything about this, it is new, so why not spare a bit of money over buying it from the store?
This is coupled with an used but perfectly working Maf GT, which is always needed when you supercharge your VQ.
I will consider offers if you want to buy uprev tuner and maf GT individually.
-Now for the SC kit.... its the Tuner version from HKS , so it does include everything needed for plug and play installation EXCEPT FUEL SUPPLY AND ECU MANAGEMENT . So , you only need to buy a set of injectors and a fuel pump (cheap, about 250 $ for oem R35 480cc injectors and 80$ for a walbro fuel pump) , then map the car with uprev.
THIS KIT ALSO HAS THE GTM MODS : larger impeller intake for better flow, 90mm pulley (stock hks included is 95mm) for about 9psi , and larger intake pipe.
The kit is complete with every part, belts, pipes, intercooler, oil, screws, and everything needed for the install!
I will also supply the officiale installation manual and UPREV ROM MAP , used for running this kit on a stock vq35de , which you can use as a base map (with this very conservative map on stock engine, r35 480cc injectors and walbro 255 fuel pump, the car was producing around 360 rwhp and 330 lbs ft of torque)
80-17759362_10210874925543574_378782261_o_07721ea545316636a0af9de9fbde3fc7ceb14ab3.jpg
Edited by Dr.Factory
Have removed your email as because this is an open public forum you may get lots of spam otherwise.
Please could you add whether the cost includes postage or is for collection. Also your location would be good.
Done, sorry! I copy/pasted from my ad on another forum... also changed the price from dollars to pounds :)
I am in Italy but will ship with courier worldwide included in the price .
Hi Dr. Factory, just curious about your power numbers...is this bhp or rwhp? The reason I ask is that I am used to the rwhp as this is what is used in the US. Here in the UK they use bhp most of the time. If 360 is rwhp, then your bhp is certainly higher. This may help your claim with your hp numbers and might help with you ad as well.
I know the kit is for de engines, just wasn't sure if any of the guru's new weather this could be fitted to a HR in some way or another.
Happy to be corrected if I'm wrong. ;)
The HR engine has two throttle bodies/intakes. For the charger kit to work you'd need, I'd imagine, some work around that; lots of extra pipe work, new plenum chamber etc etc.
Not saying that it can't be done just that this is AFAIK a specific kit for the 350Z DE engine so in answer to your question it won't fit a HR as is. :thumbs:
Yes I mean 360 hp at the wheels, equivalent to about 400 bhps at the crank !
The kit is meant for de engines, and I am 99% sure it fits perfectly also on de revups . For sure it doesn't work on hr engines due to the double intake as mentioned before !
