4.38:11 Diff in an 07 350z?
Terence Bower
Hi,
Are you talking final drive? If so think there's a slight error with the numbers. To my knowledge there is a 4.08 (or 4.1) and 4.36 available and the stock ratio is 3.5
Changing the final drive does make a big difference, I've just changed to a 3.9 and was quite surprised how much difference it has made, both to how you can work the gear box now to keep the engine on song and where the revs now sit cruising on motorway runs. On paper it doesn't look like much but in the real world it does. The 4.08 upwards I would reserve for a track only car as its a bit full on for an every day road car in my opinion but each to there own
I nicked this from the web..........gives you the idea
STOCK 3.538 Gear-- ECU REFLASH 3.538 ---HR Engine
6600 Rpm Redline -------7200 Rpm Redline-----------7500 Rpm Redline
First -----38mph ------First-----42mph-----------First-----43mph
Second ----62mph-------Second----68mph-----------Second----71mph
Third -----89mph-------Third ----97mph-----------Third----101mph
Forth ----114mph-------Forth----124mph-----------Forth----129mph
Fith -----144mph-------Fith-----158mph-----------Fith-----164mph
Sixth ----182mph-------Sixth----199mph-----------Sixth----207mph
No Reflash 3.9 Gear -- ECU REFLAH 3.9-----HR Engine
6600 Rpm Redline ----------7200 Rpm Redline-------7500 Rpm Redline
First ------35mph-------First ---38mph-----------First-----39mph
Second -----56mph-------Second---62mph-----------Second----64mph
Third ------81mph-------Third----88mph-----------Third-----92mph
Forth------103mph-------Forth---113mph-----------Forth----117mph
Fith-------131mph-------Fith----143mph-----------Fith-----149mph
Sixth------165mph-------Sixth---180mph-----------Sixth----188mph
No Reflash 4.083 Gear-- ECU REFLASH 4.083--HR Engine
6600 Rpm Redline ------------7200 Rpm Redline---------7500 Rpm Redline
First ------33mph--------First ---36mph----------First-----38mph
Second -----54mph--------Second---59mph----------Second----61mph
Third ------77mph--------Third ---84mph----------Third-----88mph
Forth ------99mph--------Forth---107mph----------Forth----112mph
Fith ------125mph--------Fith----137mph----------Fith-----142mph
Sixth -----158mph--------Sixth---172mph----------Sixth----179mph
