[SOLD] KAAZ 1.5 ways Super Q LSD for vlsd equipped 350z
Dr.Factory
Price: SOLD
Condition : Used but as good as new, bought new in november 2016 and used until now for less than 4000 miles with 2 oil changes inbetween ( no signs of metal shaves, even the slightest one ) ... just removed from the car in 100% working order.
Description:
THIS MODEL IS INTENDED TO FIT INSIDE STOCK VLSD CASING AND AXLES, DOES NOT FIT ON THE BASE OPEN DIFF ( unless you swap the axles or other mods which I don't now about ).
SO ITS DIRECT PLUG AND PLAY INSIDE STOCK VLSD.
No extra parts needed for installation, I even reused factory seals and bearings (a good machine shop knows how to take them out without damaging them). Of course it is essential for proper installation to restore factory free play beetween pinion and ring.
The diff is the super Q version which ensures quieter and smoother operation over normal plate lsd ... it is perfectly quiet except on very tight turns at slow manouver speed, which is normal.
1.5 ways means it fully locks under acceleration and partially on deceleration, actually it means the car will have ton more traction and control compared to stock vlsd , perfectly stable under deceleration (so perfect for street and slippery situations ) , and no push or understeer whatsoever with a correct suspension setup. It just drives wonderfully.
I am just selling this because I am selling the car.
Contact me at federico.puleo.87@gmail.com for any info !
Edited by Dr.Factory
  • 2 months later...
  • 3 weeks later...
