Rob350 Posted May 3, 2017 Share Posted May 3, 2017 As youve all read many times no doubt... I have p0430 or 420.. cat below efficiency... A couple of mechanics suggested cataclean to see if it it clears the light even for a few days so i could at least have a good educated guess that my cat is dead.. Anyone used it?? Or reccomend it or avoid it?? Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 4, 2017 Share Posted May 4, 2017 No worse than a bottle of Redex. Won't do any harm, but also I don't expect it to work miracles either. If you're going to use anything, you want one of the aerosols you spray into the intake post-MAF whilst someone keeps the engine ticking over to 2K rpm: That stuff clears A LOT of crap out of teh system, you'll see clouds of black smoke billowing down the street! I used to use the 10K Boost stuff, but it doesn't look like you can get it any more sadly. Quote Link to comment Share on other sites More sharing options...
Jay84 Posted May 4, 2017 Share Posted May 4, 2017 (edited) Halfrauds do an £85 treatment where they fill the cats with an expanding foam. They go in through the 02 sensor port, leave it to soak, then blow it out. I used it on my my new hfc's before fitting them and a lot of crap blew out. Looks like this... Rather than having a cleaning agent that becomes active after combustion, its soaks into and cleans the cats directly. Edited May 4, 2017 by Jay84 Quote Link to comment Share on other sites More sharing options...
