Cray Z Posted April 27, 2017 Share Posted April 27, 2017 Has anyone done this in exchange for the fair lady Z ones? I have just ordered some up, but the car is brand spankers so a bit dubious about pulling the old badges out :o Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted April 28, 2017 Share Posted April 28, 2017 There's no reason not to do it, it can easily be done without damaging anything. Use a thin piece of plastic (break a plastic fork for example), to poke some dental floss under just one edge of the badge, then use the dental floss like a saw working your way through the adhesive. Adhesive remover to clean the mess, new badges will have new adhesive ready to go! HTH! 1 Quote Link to comment Share on other sites More sharing options...
Cray Z Posted April 28, 2017 Author Share Posted April 28, 2017 There's no reason not to do it, it can easily be done without damaging anything. Use a thin piece of plastic (break a plastic fork for example), to poke some dental floss under just one edge of the badge, then use the dental floss like a saw working your way through the adhesive. Adhesive remover to clean the mess, new badges will have new adhesive ready to go! HTH! Thanks Bud! So easy enough then? Any recommendations on the adhesive remover? I have panel wipe and thinners. Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
xscotteex Posted April 28, 2017 Share Posted April 28, 2017 Apply some heat with a hairdryer to help with breaking down the adhesive too. Obviously don't use a heat gun lol Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted April 28, 2017 Share Posted April 28, 2017 (edited) Aashen is right for most badges, but I am guessing you are on about the burger badges for your 70 Nismo? These (front and back) are recessed into the bumper so the floss trick didn't work. Annoyingly, as I also need to do this soon. From what I've read online you use a hairdryer or similar to gently heat up the badge and warm the glue. The super gently pry the badge away with something soft/plastic to avoid damaging paint. Edited April 28, 2017 by mattross1313 Quote Link to comment Share on other sites More sharing options...
nrenz123 Posted April 28, 2017 Share Posted April 28, 2017 A hair dryer definitely makes the removal process a lot easier. I've used warm water and some tar/bug remover to get rid of the remaining residue previously. Quote Link to comment Share on other sites More sharing options...
Richf Posted April 28, 2017 Share Posted April 28, 2017 Yepo warm up the old badge with a hair dryer before pulling it off , if you are gentle you can sometimes lift them with your fingers and the sticky pad stays on the badge Quote Link to comment Share on other sites More sharing options...
Cray Z Posted April 28, 2017 Author Share Posted April 28, 2017 Aashen is right for most badges, but I am guessing you are on about the burger badges for your 70 Nismo? These (front and back) are recessed into the bumper so the floss trick didn't work. Annoyingly, as I also need to do this soon. From what I've read online you use a hairdryer or similar to gently heat up the badge and warm the glue. The super gently pry the badge away with something soft/plastic to avoid damaging paint. Yes, on the Nismo, hence a little anxious, if it was any of my other cars it would be no bother lol! Hairdryer trick sounds good! The vendor of the Z badges recommended the hairdryer too. I have one specifically for car stuff lol! i also have a nice selection of bright orange plastic trim removal tools, so will try these. I am going to put a gloss black badge on the front and chrome on the rear. Quote Link to comment Share on other sites More sharing options...
Richf Posted April 28, 2017 Share Posted April 28, 2017 Yep be very very careful prying the badge up with a tool its super easy to mark the paint Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted April 28, 2017 Share Posted April 28, 2017 The 350Z badges on the front are also recessed, hence the need for the broken plastic fork. But I agree, it's not easy to get the floss in in the first place with recessed badges, heat will certainly help, but also soften the paint, so be EXTRA careful if you apply heat!! Quote Link to comment Share on other sites More sharing options...
Strudul Posted April 28, 2017 Share Posted April 28, 2017 Hot water bottle + a credit card works best. Quote Link to comment Share on other sites More sharing options...
W8BGS Posted May 2, 2017 Share Posted May 2, 2017 On previous cars I've used small cable ties to poke through the adhesive/under the badge and use the saw method mentioned above and the badge came off quite easy 1 Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted May 4, 2017 Share Posted May 4, 2017 ^ +1 on that method for recessed badges. Take your time, heat slowly and evenly and be in no rush to get the badge off. Better to take 3 times longer and damage nothing. Quote Link to comment Share on other sites More sharing options...
