freps25 Posted April 27, 2017 Share Posted April 27, 2017 (edited) Bonjour My tutorial ni french on this forum: http://www.notre350z.com/forum_notrez/showthread.php/22344-Utilis%C3%A9-la-source-video-en-roulant Désolé mon anglish est mauvais ... Mon problème: Lorsque je retire le frein à main, la source vidéo de la coupe gps .... (désactivé) Retrait de la sécurité de la chaîne de freins ou regarde les vidéos sur les gps. Il doit s'agir d'une sécurité pour ne pas Regarder des vidéos pendant la conduite Comment supprimer cette sécurité? Je veux regarder l'affichage vidéo lors de la conduite (télémétrie depuis la vidéo capture rca du 370Z) Comment supprimer cette sécurité? Je veux regarder l'affichage vidéo lors de la conduite (télémétrie depuis la vidéo capture rca du 370Z) Merci Edited April 28, 2017 by freps25 Quote Link to comment Share on other sites More sharing options...
brillomaster Posted April 27, 2017 Share Posted April 27, 2017 well, it used to be that a cars handbrake handle simply connected an earth to turn on a dashlight warning that the handbrake was on... so id start by removing a bit of trim round the handbrake, and disconnecting that switch if there is one, see if that works? the video feed might be simply tapping into that? Quote Link to comment Share on other sites More sharing options...
Richf Posted April 27, 2017 Share Posted April 27, 2017 Its not that easy on the 370z as the car uses the handbrake signal AND GPS speed I looked into this with mine , a company in the US sells this kit http://www.carkitcompany.com/nissan-370z/nissan-370z-bypass-remote Which i assume will work on Euro models Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted April 27, 2017 Share Posted April 27, 2017 Google for 370Z DVD Override. A guy on another forum sells them, I'll be getting one in the future if I plan to install a tablet or similar like you Quote Link to comment Share on other sites More sharing options...
freps25 Posted April 27, 2017 Author Share Posted April 27, 2017 (edited) I managed to make the change. Now I can watch videos (telemetry) with a device plugged into the RCA video on GPS screen, (hand brake removed) => Wire number 65 is that of the handbrake switch (used to set the gps safe ((no video when driving)) It is behind the car radio, on a large connector. Cut the thread number 65 => Wire connector side = connect it to a ground => Feather side wire = isolated and leave Bye I managed to make the change. Now I can watch videos (telemetry) with a device plugged into the RCA video jack, rolling (hand brake removed) Edited April 27, 2017 by freps25 Quote Link to comment Share on other sites More sharing options...
freps25 Posted April 28, 2017 Author Share Posted April 28, 2017 My tutorial ni french on this forum: http://www.notre350z.com/forum_notrez/showthread.php/22344-Utilis%C3%A9-la-source-video-en-roulant Quote Link to comment Share on other sites More sharing options...
